About 250 to 300 cfm at the 2bbl. rating, you would be better off to find a q-jet manifold and q-jet to put on it. It will not over carb due to the air valve design and will probably pickup both mileage and power.
A 500 cfm 4bbl will not be overcarbed for a 283....You will have to change the intake for a 4bbl......an Edelbrock Performer would be a good choice. Will take spreadbore or squarebore.
Ontario Rodders |
65 I believe.............That one in the picture is a later one....maybe 68-74, judging by the lack of oil fill hole and spring choke setup. It would work on your 283, but you would have to get valve covers with an oil fill access.
Ontario Rodders |
These are really good carbs for a mild street smallblock, it'll work excellent on that 283. I don't think Holley has made them for quite awhile but it was very common to find them under hoods in this area years ago. Usually ebay has a good selection. |
I would go with the edelbrock....if nothing more than, you can bolt either a spreadbore (Quadrajet) or squarebore (Holley, Carter, Edelbrock) to it........
The Quadrajet that you are looking for is a pre 75 (I think)....the serial # will start with 70...not 170.......The sreial # is stamped up the side of the back barrels on the drivers side of the carb. Love the car BTW...I have a 62 Canadian Pontiac which is very similar.
Ontario Rodders |
poncho62
Nice car. Have you ever been to the Back to The 50's in MN one of the BEST car shows around , 11,000 plus cars each year. Next years show June 20,21,22 2008 Check out the web site at http://www.msra.com/ |
What would be a better choice the 1965 quadrajet intake?
You could also get an aluminum stocker from an 80s 305 Q-jet Camaro for almost nothing. The carb & air cleaner from the same car would work well. |
| 283 stalling, carb size etc... | 59vette | Engine | 7 | 07-04-2007 03:29 PM |
| 283 to 302 | jakester | Engine | 16 | 05-22-2007 08:41 PM |
| Carb question revisited | Bob23T | Engine | 2 | 10-07-2005 04:32 PM |
| Hi All I just Joined, Questions Re:454 rebuild | Gay-Shark | Engine | 8 | 11-29-2003 10:25 AM |
| Which engine 283 or350 | newjpguy | Engine | 14 | 03-25-2003 06:15 PM |
