Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 283 rockers
Thread: 283 rockers
Old 12-01-2012, 04:13 PM
Richiehd's Avatar
Richiehd Richiehd is offline
JS-70
Originally Posted by Mertz View Post
I have decided that the stock stamped rockers are not good enough for my build and want to use some roller tips like I did on my 350. The heads have a narrow slot for the pushrods. The cam is a MTC-1 low lift with new z28 valve springs. The pistons are .030 in the hole. The heads and block have been decked (0.017) and I used a .028 head gasket. Can I or should I use 1.6 rockers? Do I need to get self aligning rockers?
Regular rockers will work but you may have to lengthen the slots for the 1.6 rockers. Myself , I would just put a good set of 1.5 roller rockers on or if you just want better accuracy, a set of Comp Cams stamped rockers with roller tips. These come in a 1.52 ratio and work well on the 283. They are priced right too. I think you might like a thinner head gasket too (back to that "quench" thread)
