283 running rough - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2012, 06:55 PM
67MercCat's Avatar
Junkyard Dogg
283 running rough
Hey Fellas, I'm working on my buddies 57 Chevy Belair and he said that he recently had his engine rebuilt.
The rebuilder didnt put in a new distributor cap so we replaced the cap and buttoned everything back up. It was a little out of timing so we used the timing light and set it to 6 degrees advance. It's still runs like crap and sounds like its missing. Turns out that cylinder 3 and 5 are not firing at all. When we took it for a test drive, it shifted hard thru all the gears.
1) Should we set the timing without the vacuum advance hooked up?
2) would a bad vacuum modulator cause a bad idle. Only mentioning it because of hard shifting.
3) do you think new plug wires will do it. Some of them would shock me to the touch.
Thanks guys
Old 01-29-2012, 08:14 PM
DoubleVision's Avatar
First of all, find out why its not hitting on the given cylinders, run a compression check, this will make sure that the issue maybe outside the ignition system.
As for your question, yes you set the timing with the vacuum advance disconnected and plugged, it should be reconnected after the timing is set to a full time manifold vacuum source, one that pulls vacuum full time including idle. Shoot for 12 degrees before top dead center with vac advance disconnected. Reconnect vac advance after setting, recheck timing, the new setting should be 18 to 24 degrees before top dead center. When you connect the vacuum advance its going to idle up so be prepared to reset the idle and the idle mixture there after. The rough idle is likely caused from it not hitting on 2 cylinders plus the low spark timing.
Old 01-29-2012, 08:18 PM
Chevolla's Avatar
yes set timing with vac adv disconected
trans should be hooked up to vac source or it will shift hard
yes change wires and check firing order
good luck
Old 01-30-2012, 08:28 AM
67MercCat's Avatar
Junkyard Dogg
thanks guys, I figured that it might be something like that. The guy who did my buddys trans did a really sloppy job, so I'm going to change his vacuum modulator and hose.
As for the timing, I'll go at it again this weekend, one of my buddies told me to do a compression check too, but I'm gonna check again to make sure for certain that they aren't sparking.
I mean I worked with plugs a long time and never been shocked by touching one. I think that he needs a new set of plugs because the spark could be jumping thru the cheap insulation.
thanks fellas
Old 01-30-2012, 08:57 AM
T-bucket23's Avatar
Wiki Edits: 26
What type of ignition does it have. If it is an original point distributor, check the point gap before messing with timing. Should be .017 or if you can find a dwell meter 28-32 dwell.
Chet
Old 01-30-2012, 09:43 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Originally Posted by 67MercCat
I mean I worked with plugs a long time and never been shocked by touching one. thanks fellas
That's part of the initiation, you don't know what your missing!
Semper Fi
Old 01-30-2012, 10:12 PM
67MercCat's Avatar
Junkyard Dogg
@ t-bucket23 It is an original points distributor. I never really figured out the whole points things any of you guys feel like giving me a quick run down on how thats done? I mean I know a little something, but mostly just bolt on and go type of stuff.
Old 01-31-2012, 07:21 AM
T-bucket23's Avatar
Wiki Edits: 26
You need to get the rubbing block on the points on one of the highs on the cam in the distributor. The points need to be set at .017-.019.
More that .003 in either direction and it will run like crap as the coil charge time will be to short or the field collapse will never completely happen. Both causing weak spark. It is not hard if you know how to use a feeler gauge.
Chet
Old 01-31-2012, 10:03 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Make sure the condenser is in good condition or you will get a weak spark.
Old 02-01-2012, 08:07 AM
67MercCat's Avatar
Junkyard Dogg
I have a 32 blade feeler gauge so I'm going to pull it apart this weekend and take some pictures so I can accurately identify the parts your talking about. It's time for me to stop running from this!!!!!
@ lg1969 Yeah the condenser is new, actually all the parts in the distributo are new, which is why I'm thinking that the points need to be set.
Old 02-01-2012, 11:17 AM
Cat, No offense but the best place for points is the trash. There may not be room for a HEI or if the desire is to keep the appearance as authentic as possible then I would get a points conversion kit then you can throw the points in the trash. The conversion unit fits right under the cap, gives you just as strong a spark as a HEI does with no hassle with no gaps or dwell adjustment. Check it out at this link:
http://www.pertronix.com/prod/ig/ignitor/default.aspx
Old 02-01-2012, 12:57 PM
FEELER GAUGE?!?!? I always used a matchbook
305 running rough 400smb_s10 Engine 1 02-27-2011 10:04 AM
2.8 v6 rough running dragonxdynasty Engine 3 07-03-2010 07:20 PM
rough running 305 daledove Engine 4 09-12-2008 09:13 AM
SBC 350 running a little rough 75gmck25 Engine 1 12-27-2007 04:26 PM
Rough running 350 nelipot Engine 6 08-26-2002 02:29 PM
