283 sittin for too long. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2013, 01:50 AM
I JUST RECENTLY BOUGHT A CHEVY 283 WITH TRANSMISSION . I'M WONDERING IF ANYONE HAS ANY HELPFUL HINTS ABOUT MAKIN THIS MOTOR RUN GOOD. UT SAT OUTSIDE FOR A FEW YEARS AND water got in one of the cylinders. Any reply will be appreciated. Thanks,ben Hayden
Old 05-05-2013, 05:38 AM
Your going to have to bore it and with a 283 you can go 125 thousands. That will give you a 301. They were real popular in the early 70's. pretty much what the first S 28 motors were.
Old 05-05-2013, 06:08 AM
283?
IT'S already been bored .030. I hope the one cylinder that has water damage will clean up cuz u don't want to go more than .030 rite? Wat cfm carb wood u recomend?
Old 05-05-2013, 07:54 AM
vinniekq2's Avatar
bore it 060,use a 600 cfm carb.If its a hot rod then a 600/650 double pumper works well with matching speed equipment.If its going to be close to stock then use a 550/600 Vs.
Old 05-05-2013, 08:14 AM
It would be cheaper and make more power if you buy a complete 350 vortec engine from a 1996 to 2000. Then get a vortec intake and holley carb and drop it in.
These engine are cheap, have roller cams, and vortec heads. It most cases you can drop them right in. Should be able get one for 500.00. Make sure to get a complete engine (fan to flywheel) as the little stuff will nickel and dime you to death.
The only problem is these blocks don't accept a mechanical fuel pump.
Old 05-05-2013, 09:53 AM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
i love them ol 283's. with little effort they will spin to the moon. build that 283. not one dang thing wrong with um.
Old 05-06-2013, 10:48 AM
not ALL blocks will go .125" overbore (the magical 301). And even when they did go that far, theres no room for clean up, so when its tired, its done. I'd go .060". Have it magnifluxed and sonic checked before you get too deep in it. there isn't a lot out there for piston selection at a cost effective level anymore, and you'll want to watch your head and cam selection with a small engine. Also, you'll probably want to plug the road draft tube and use a PCV system - there are ways you hide them fairly well in plain sight.
Startin up an engine been sittin' awhile smurbs Engine 39 04-22-2008 12:57 PM
I was just sittin here enjoying reading engine posts and wondered BBC, SBC? fumplet Hotrodding Basics 22 09-25-2006 03:40 PM
car bin sittin for 6 months.. Trav Engine 21 03-03-2004 12:08 AM
car sittin on bloks for 12yrs stoney 81ta General Rodding Tech 11 01-19-2004 11:30 PM
car has been sittin 12yrs stoney 81ta Suspension - Brakes - Steering 10 01-02-2004 05:03 PM
