283 small block/Vortec heads combo - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2009, 11:54 PM
Hello. I have a 283 punched .030 (288 c.i.) with stock heads. I have a pair of vortec heads with 1.94 and 1.50 valves. Will the vortecs work with the 283 punched out to .060, or are the valves still too big? I believe the combustion chambers on the vortec heads will also lower the compression a bit on the 283. If the heads won't work, I'm just going to get a 350 or 383 short block. Thanks.
Old 11-14-2009, 12:56 AM
Assuming you had a 283 +.060 with stock deck height, stock type flat top pistons (somewhere in the ball park of -13cc), 64cc vortec heads, and a steel shim gasket (.020 compressed thickness), you would be sniffing around 8:1. Even if you zero decked the block, you would be in the neighborhood of 8.35:1 with everything else being the same.
I would be looking for some kind of dome piston if you go with the vortecs. Try Egge, i think they make the dome GM style 283 pistons that the corvette's used when the first double hump heads came out.
The vortec valve size should work. The heads would work very nicely if you can get the compression ratio up towards 9-9.5:1. With a good steet cam, 600cfm carb, and a good gear, it would be a peppy one. With a small cam, it would make for some good mpgs.
Old 11-14-2009, 02:14 AM
you r ok.should be a fun combo.had a120 over 283 i think like in 1978 with a small crower cam 288/300-500/510 with some 194 fuelis a torker 600double dumper in a vega th350-fairbanks 10inch con-8 3/4 chr rear with 11s and the car would hum-beat some bad actor rides-of course the motor was singing at A mere 65 plus.no sweat.good luck with your not so normal endeavor.
Old 11-14-2009, 02:44 AM
forgot to mention same car stock L82 motor with a real baby TRW cam -solid-Smokey Ram 800 double dumper-50cc rio pumps front and rear 31fr 33 squirters----chewed the beep beep guys for breakfast-the 7000 mile real BOSS 302 OR the supposed king of the city in his mini domed 12.5 292 turbo headed tunnel rammed 57 sedan delivery..WE NEVER LOST-NOT ONCE.Just skills and being very lucky.Street racing in New Bedford.It use to be a beautiful thing.
Old 11-14-2009, 08:00 AM
Thanks all. The 283 has flat top pistons and the cam I chose is similar to an RV grind so I can get some more torque in the low rpms.
Heads for my 283 build. Thoughts?! V8 Super Beetle Engine 44 05-07-2008 10:51 AM
SBC 283 Heads Wadeamca Engine 4 02-01-2008 09:38 AM
283 Heads Question budthespud Engine 6 06-07-2007 07:01 AM
283 w/305 Heads youngc0@mchsi.com Engine 5 04-14-2006 10:06 PM
XE274H cam sound like? Heads Choice? Help me decide on combo for chevy 400 Warrant Engine 10 03-01-2006 02:58 PM
