Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 283 vacuum advance
Old 01-14-2006, 08:34 AM
onovakind67 onovakind67 is offline
Is this a stock engine? What's the manifold vacuum at idle? How much vacuum does it take to run the can? You want to select a can that is all in at idle then hook it to manifold vacuum. If you need to limit the vacuum advance, you can get limiters from guys like this:
