hello, my names Jason, i just got an s10 with a blown up 4.3 v6 and i want to go to a v8. i got a 283 but needs rebuilt and the rebuild kit is expensive so i was wondering if i put a 350 crank in it what else would i have to change. basically I'm on a tight budget and need to get it rebuilt as cheap as possible but still have it a screamer. It will be fuel injected
a 350 crank won't fit in a 283 block. 283 has smaller bearings and there would be clearance issues. even then it would take customs pistons to work with it.
you're better off buying a running 305 or 350 out of a wrecked car or truck
Are you REALLY from "Hicktown" S.C.? Anyway, my suggestion is to go to a few towing yard type auctions. You'd be surprised what you can buy. $100.00 will get you a running, driving car many times. Use what you can, part out what you can, then hulk the rest out.
Find someone that'll trade you the 283 for a 350. That's what i did. A 350 will make for a faster truck for less money too. 283's aren't as common as a 350 so the parts for the rotating assembly (bottom end) will be more expensive. Chances are you'll find someone looking to have a more unique engine for their nostalgic build. :thumbup:
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
