289/302 valve adjustment
Ok here goes. I bought a 65 comet caliente that was suppose to have a 289 in it. I have been having some valve tapping noise and my chrome valve covers were more rust then chrome so I bought a new set of valve covers and planned on adjusting my valves when I changed them out. First thing I noticed was that the heads had 302 cast in them between two of the valve springs. Im guessing that means that the heads are 302's. It could be the whole engine is a 302. It runs strong and has alot more pep then I thought a 289 would have. The main problem is that my rockers are loose but the nuts are tightened down as far as they will go. The studs are larger at the bottom then the top. The holes the pushrods go through are perfectly round. And the point where the valve stem meets the rocker arm has a rail on each side to keep it from slipping off. My question is how do I get rid of the loose rockers.
loose rockers
I have had success by replacing the pushrods and rockers (along with the balls that sit in the rocker. 302s have the valves set by tightening the nuts all the way down.
Early small-block Ford engines had adjustable valves that could be tightened to zero lash, then another 3/4-turn. Later ones had a non-adjustable valve train, and this is probably what you have. Comp Cams makes a set of lock-nuts and beveled spacers that can be used to convert to an adjustable valve train.
http://www.compcams.com/Technical/Cu...ML/315-319.asp (scroll down about 3/4 of the way to Adjusting Kit) |
i believe around 1987 ford started using pedestal mount rockers on their windsor heads, which are tightened down all the way (5/16-16 bolts) with shims to take up the slack. early windsor cylinder heads were stud mounted rockers that you could adjust. crane makes a pedestal-to-stud conversion that just bolts in and uses stock length pushrods. you can use roller rockers with it too, going away from the pedestal mount rockers altogether. you just cant too radical of a cam profile, nor can you spin the rpm too high....
Thanks for the quick replys guys. I found the kit that jimfulco gave me. From what im looking at it seems that a thick washer on each stud would do the trick. This may sound a litte "shade tree" but I dont intend to race the car. Somewhere in the back of my mind I remember seeing something like this on a SBC. I may head out to the junkyard and look at some heads and see what I can come up with. Thanks again guys.
Even with the use of the COMP CAMS KIT, I would worry about having the correct pushrod length for proper geometry. CAUTION! Old Guy Passing Through...
As the old guy passing through said (sorry Gary, you started it
), It sounds like the parts were just thrown together. If it is a 289 and they put later non adjustable (these are different than the bolt on type) heads on it the pushrods are probably the wrong length, the 2 heads used different length push rods. From the description you gave these are not the later fulcrum rockers that will benefit from shims. Shims will not only be waste of your cash, they will do nothing (not even fit) for these heads. The positive stop studs, have as you described, a "swollen" stud part way down that limits how much you can move the rocker down. The fulcrum style that came later are attached with a bolt and are aligned by the notch in the head that the fulcrum rest in. These are the type that can use the shim set, not the kind you've described. Listen to the old guy, and this younger more handsome guy . I see after looking at the link, the kit described is for the pedestal style, so it would work, but have to agree with Gary regarding pushrod length even when those are used.
[QUOTE=Wooky71] From what im looking at it seems that a thick washer on each stud would do the trick.QUOTE]
That was my first thought (although I was thinking about a Pontiac at the time). Note that the inner diameter of the Comp spacer is stepped, not straight. Also, you might find that your stock rocker nuts are not lock-nuts, and will unscrew during vibration. |
However you do it, whatever parts you have or end up with,
you want a certain amount of preload on the hydraulic lifters. Crane & Comp both recommend .020 to .060 preload. Here's how I did mine. You may not have to get quite so fussy on measuring, but if you do a good job your motor will run better and last longer. http://www.lincolnsonline.com/article78.html |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| GM fast burn heads | batman09 | Engine | 1 | 10-26-2004 09:32 AM |
| Valve lash adjustment, Now I'm confused? | Jag Daddy | Engine | 5 | 04-15-2004 11:27 PM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
