289 Ford pcv ventilation help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2010, 02:22 PM
Hey fellas! Im currently running a 289 in my Model A P.U., .040 over, cammed, worlds heads, holley 600 carb., 3000 stahl. Awsome street engine, runs flawless!
Heres my problem, i use about a quart of oil every 300-500 miles consistantly. When i pull the breather/oil fill off the drivers side valve cover there is NO blowby showing. When i pull the pcv out of the pass. side there is NO blowby. all the plugs look great and consistant in color, BUT when i pull the pcv hose off the carb. there is oil dripping out of the hose! Im using a motorcraft EV-50 valve and the valve covers are tall cast with baffles. Should i look into a different pcv valve?? Kinda stumped here!
Ford 289 with H pipe? 70gmcer Engine 16 03-25-2010 09:45 AM
Picking a Ford sb 289 Cam 66Moostang Engine 6 12-13-2008 04:02 PM
ford 289 valve lash help pi71 Engine 6 08-22-2007 08:35 PM
t5 swap on pre '65 ford 289 flamedfordbronco Transmission - Rearend 2 10-25-2005 06:00 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
