289 ford vs 283 chevy?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2010, 05:29 AM
Which one is cheaper to get 350 hp out of?
Old 03-06-2010, 05:46 AM
32Essex's Avatar
Give some details, are you going to stroke it ? buy used parts? ie roller cam, alum. heads? gas or alcohol ? injected or carb ? unlimited compression?
Old 03-06-2010, 05:55 AM
i want the smallest cubic inches as possible. i can buy used parts. i want stock cast iron heads. whatever size cam that will get me to 350 hp. gonna run 110 race fuel with a carb. and i like the sound of high compression so yes, unlimited compression.
Old 03-06-2010, 06:12 AM
32Essex's Avatar
I'd go with the chevy, 283 high compression pistons show up at the swap meets, and craigs list, ebay. I bought a new set of 327 trw .150 dome pistons a couple of years ago at the Decatur swap meet and they turned out to be 302 pistons, you can't tell without looking up the numbers! I just pulled the 302 out of my 55 drag car, I don't know how much hp it made ,but it's best in a 3500 lb. car was 7.85 in the eighth, it has brodix heads and a Predator, and it had a 4-speed .
Old 03-06-2010, 06:22 AM
your goal 350HP/283 cubes= 1.23 HP per cube...
that's not a used parts/junkyard parts cheap motor...
and it is a "race only" high narrow rpms operating range motor,,,not suited for the street...
suggestion:
go buy a "how to build a high performance motor book" at your local parts store and study it carefully...
Old 03-06-2010, 06:34 AM
its gonna be stricktly offroad
Old 03-06-2010, 07:11 AM
red65mustang, i have a suggestion for you, stop posting ******* comments like "go buy a how to (insert moron quote here) book", try actually being helpful instead of one of those nitwit naysayers all the time, you said 600 hp/600 trq wasnt possible in N/A a 496 stroker, but it happens every day. stop being a dick and get off your pedestal man.
Old 03-06-2010, 07:21 AM
Frisco's Avatar
Glad To Be Here
You are a newcomer to this site. If you think you wish to be helpful, then post what you have to offer.
Berating a popular member here that has offered many many excellent posts of advise, will not get you anywhere except be banned. I have reported your post as being offensive and not offering any helpful or useful advise.
Old 03-06-2010, 07:31 AM
poncho62's Avatar
Wiki Edits: 5
I agree......and you b00tz can take 2 weeks of to think about it........and, I am leaving the post as is, so all can see who the dick is.
Old 03-06-2010, 07:34 AM
Wiki Edits: 31
you want a 350/383 stroker then.. you need the low RPM torque.. 283/289 isn't going to provide what you need. there going to make there power in the higher RPM's where you won't need when offroading
Old 03-06-2010, 08:14 AM
sqzbox's Avatar
My pipes are my music
Have you thought about a turbo system. The 289 is a quick revving, well balanced engine and with the right cam, you wouldn't need pistons and 110 race gas!
Just an idea.
Old 03-06-2010, 08:18 AM
no turbo. n/a is what im looking for. matt167, what is the 350/ 283 stroker your talking about?
Old 03-06-2010, 08:44 AM
Wiki Edits: 31
sorry, I misstyped the 2.. supposto be 383 stroker
Old 03-06-2010, 08:57 AM
ive thought about the 383 but im looking for a low cubic inch motor
Old 03-06-2010, 09:00 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Poncho, I love you man .
Now back to the OP. I know either engine can make pretty good screamers, But like Sqzbox said the 289 high revving little engine the right cam and heads it's gonna scream trust me. I did one for my 65 a few years ago comp cam kit heads stock heads reworked 3 angle valve job comp springs screw in studs and guide plates. Edelbrock performer intake with a 600 Holley, That thing is still screaming if i can find or remember the cam specs i will post them for you. This is all JMO.
Cole
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Opinions needed: chevy vs. ford...... woodscavenger Hotrodding Basics 20 07-29-2007 07:04 AM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
Ford 9 inch to Chevy 4.75 pattern questions 3100 Special Transmission - Rearend 14 01-21-2006 07:29 AM
Chevy of Ford? gt2betubbed Hotrodders' Lounge 12 11-27-2003 06:42 PM
