289 hipo - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2006, 09:18 PM
289 hipo
just need to know what the big deal is over a 289 hipo engine are they that powerfull.i work with a guy that has a very sweet 66 gt350 with a 289 hipo thats all he talks about he even bought another engine that needs rebuilt for big bucks.just trying to understand thanks ken.
Old 05-23-2006, 09:29 PM
lelandl's Avatar
Fiero2M8
It all depends on your likes. The 289 hipo was a sweet little engine. 271HP and 306HP in Shelby form. Solids, aluminium intake, 480cfm? 4bbl, high flowing cast iron exhaust, dual points, 3/8 rod bolts, forged rods (The rod length was used for the Boss 302)
Old 05-24-2006, 11:11 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
bottom line.
'65-'67 2V rated @ 200 hp
'65-'67 4V rated @ 225 hp
'63-'67 HP rated @ 271 hp
Last edited by crazy larry; 05-24-2006 at 11:13 AM. Reason: *according to my sources....
Old 05-24-2006, 12:31 PM
brainsboy's Avatar
brains
I believe they had their own heads too.
Why is it special? Its special from a collectors standpoint. Because during the muscle car era, you had muscle cars, but then you had High performance versions. Dodge had a 340 4bbl, but then it had the race version 340 six pack. Ford had 289's with 4bbl's, but then it had the race version "HIPO". Ford also had the 302, then they made one with cleveland heads it was called the "TRANS AM", but just as it was released Pontiac used the name and patend it, so ford changed it to the 'BOSS 302'.
Old 05-24-2006, 02:23 PM
lelandl's Avatar
Fiero2M8
Why is it special? Its special from a collectors standpoint. Because during the muscle car era, you has muscle cars, but then you had High performance versions. Dodge had a 340 4bbl, but then it had the race version 340 six pack. Ford had 289's with 4bbl's, but then it had the race version "HIPO". Ford also had the 302, then they made one with cleveland heads it was called the "TRANS AM", but just as it was release Pontiac used the name and patend it, so ford changed it to the 'BOSS 302'.
I don't remeber them having different heads. The build sheet I have shows the same heads with 1.780 intakes and 1.45 exhaust. Compression was 11.6 for '63 and 10.5 for 64-67 due to the different chamber sizes. (48-51CC for 63, 52-55 for 64+)
Old 05-24-2006, 03:10 PM
brainsboy's Avatar
brains
just found a site on it, they did have their own heads
http://www.hipomustang.com/images/hipoeng/
Old 05-24-2006, 05:14 PM
lelandl's Avatar
Fiero2M8
I thought you meant they had special ports or something to make the heads unique to the HP. You are correct in that they had the screw in studs and the spring cups (I didn't remember the cups). But the heads themselves were the regular 289 as far as ports, valves and chambers, the items that affect flow. I believe the Shelby version had a different cam, aluminium intake (made a mistake in my original post, the HP was cast) and tube headers, but I don't remember what other changes, if any, to get 306HP.
Old 05-24-2006, 10:02 PM
onebadmerc's Avatar
I need a bucket of arc sparks
The HP 289 had a nodular iron crank, spot faced 3/8" rod bolts, thicker main caps, screw in rocker studs, cast in spring pockets, special cast iron headers, a 480cfm Autolight four barrel carb, dual point mechanical advance distributor, high compression pistons and a solid lifter cam. Manual shift cars had a 10 1/2" clutch, standard four and two barrel carb 289's had the 10" clutch. This is about all I know off of the top of my head. If you have a HP 289 car you are a collector and know what you have. I once raced a 67 High Country Special with an original 289HP and smoked him with a warmed over 302 and 4:10 gears in a 71 Mustang. The 289HP's mustangs were not really that fast, they might pull low 16's with a good driver. As stated above, collectors value is high but if you want real power house SB Ford, build up a 5.0 or a 351W.
Old 05-24-2006, 10:34 PM
289hipo
well personally i think that the 289 is only for collectors b-cause it does not have the power of a hemi or the almighty chevy 350
Old 05-24-2006, 10:45 PM
289hipo
how crazy is that rs
Old 05-24-2006, 10:49 PM
lelandl's Avatar
Fiero2M8
At 70 more cubes I should hope a 350 would well against a 289, but I have seen 289s and 302s smoke them. Now if you want to put a 350 against a 351C or 351W, then you are talking apples and apples. And a Hemi? Different class altogether.
Old 05-24-2006, 11:01 PM
i understand what you are saying but why didnt ford slap a monster of a engine in those cars
Old 05-24-2006, 11:50 PM
"...why didnt ford slap a monster of a engine in those cars"
Because they wouldn't physically fit in the '64-66 engine compartment, the chassis couldn't handle it, and if you really wanted a monster from that era, a person should save up enough to buy a 427 Cobra instead.
A couple more tid bids.
The extra counterweight was needed to offset the weight of the heavier rods.
The motor mounts are unique to the HiPo.
I'm fairly sure the Mexican caps have a different casting # and are made from inferior metals.
Old 05-25-2006, 06:30 AM
"back in the days"...63,64,65'....club "week end" road racing was the big thing, rally racing was also a big deal,
dollars per HP and/or dollars for HP parts, K code Mustangs were a steal compared to all others (British, Italian and German mostly).....
peak HP at 6,000 rpms, .471 solid lift cam, bigger clutch, 3.89 gears, dual point, red line tires, better exhaust system etc. etc.....drive it out of the dealership and go have fun at Limerock, Riverside, etc
wish I could recall what the "Hipo" option listed for....all the above and more for like $150 extra on a $2800 car.....
the "new" Mustang "Factory Racer" is like $100,000(?)
Old 05-25-2006, 07:13 AM
lelandl's Avatar
Fiero2M8
The companies all were still playing with small blocks through these years and while I know that GM had the cube limit for "small" cars, I am not sure about Ford. Chev still had the 327, Pontiac 326, Olds 330 in the 442, Mopar 318 and 273, even Rambler with a 287/327. Then in the late 60s you started seeing the bigger smallblocks: 350, 340, 302/351, 343.
I had a 302 in a '67. It had 289 rods, ported and polished '69 heads, Offy 180 intake, custom built Thermoquad 750, flat tops (10.5:1), balanced and blueprinted, Sig Erson hydraulic cam (I believe it was 284 degrees, .504 lift, 108 center), custom large sump pan, high-pressure oil pump, dual point Mallory. With 3:91 locker and a toploader I smoked many a big block on the street with it. Nothing like the sound of a 7000rpm screaming small block.
Today, I have an injected 302 in the works and a 429 with C6 tucked away for a future project.
Need some info on Ford 289 and 302 water jackets onebadmerc Engine 5 01-09-2006 09:40 PM
LAST MINUTE HELP...289 to 302 or stroker exiled1 Engine 4 12-14-2005 03:41 PM
289? 392? 0r 351? exiled1 Engine 4 11-10-2005 04:40 PM
boring a hipo 289 65 mustang Engine 2 12-27-2002 04:40 AM
66 Stang with 289 HIPO and 4.62 gears... Tranny help USMCDCC Transmission - Rearend 4 12-23-2002 06:45 AM
