I cant imagine changing the intake just a level or two would make a huge difference though it would be somewhat better. Your gears are definitely for cruising and will probably not allow your engine to reach the range where the taller intake performs best.
Combinations are the key. If you are looking to make a difference in performance, get a matching cam and lower gears. Otherwise, save your money and keep the intake you have. |
agree, it won't make a big difference for normal rpms to put on a performer....
this chart attached is from Fletch's 5.0 site from a magazine long ago...the green line would be close to a RPM intake (hi-rise Ford 289) changing the gears directly "multiples" the torque applied to the rear tires for more push you back in the seat at all/any different rpms.... 3.00x300ft/lbs= 900ftlbs of force on the tires 3.50x300ft/lbs= 1050ftlbs of force ----- 150ftlbs diff ????? ever "try" to torque a bolt to 150ft/lbs....it's ALOT of force you really feel the difference because at 2k rpms, the torque is only roughly half the max but the gears multiply what is there |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| Fabricating intake manifold. | gemini86 | Engine | 25 | 10-02-2009 01:10 PM |
| Whats wrong with the performer rpm cam?. | 7fastelc0 | Engine | 19 | 12-09-2006 05:49 PM |
| need help with 289 intake | waycoolfairlane | Engine | 4 | 07-02-2006 09:23 AM |
| Just Got My Rpm Performer Cyl Heads...questions!!!!! | Frankoholic78 | Engine | 16 | 06-07-2006 06:59 PM |
