28oz 351W flexplate for AOD/E - 4R70W? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2005, 03:34 PM
Kinda long - sorry.
For my warmed up 351, I would like to replace my
AOD with a later 4R70W, but so far can't find a
28 oz flexplate for an /E or 4R.
Found out there are basically 2 size lockup converters.
The larger 12" (which was used with 302's) is only
good to about 5400 rpm before it starts ballooning,
but with it's larger lockup clutch has more torque
capacity in lockup. (The smaller 11" which is good to
about 6500 rpm was used only with mod motors and
of course there's no oem flexplate for any of the Windsor
motors that has the smaller bolt circle pattern for the 11".)
My 351 is built mild for mid range torque w/a heavy
car, and 5400 is plenty for my combo, plus I'd be better
off with the heavier duty lockup clutch.
Although there are oem flexplates for 302 Windsors with the
larger 12" converter, I haven't been able to find any oem
application that used the 351 (28 oz flexplate) with an /E or 4R.
With my good low & mid range torque, one of those oem 12"
converters would give me plenty stall (between 2500 & 3000
using the K factor calculation) and would let me save several
hundred bucks for an aftermarket converter which would then
put the 4R swap within affordability range.
If there aren't any aftermarket 28oz flexplates available for the
/E - 4R trans, has anyone tried swapping balance weights?
Then an oem 302 /E flexplate could be used if the weights could
successfully be swapped.
Thanks for any leads or ideas!
Old 06-30-2005, 05:19 PM
aka Duke of URL
Call your local dealer and see if they have in stock D1ZZ 6375-A. This is a 164T flexplate (28oz.) and should work on your upgrade.
If you find a used one, it should have an I.D. Stamping D1ZP-AB.
Old 06-30-2005, 07:01 PM
REALLY appreciate that!
After I posted, I again checked places like
AZone & O'Reilly's online catalogues and
did discover that i.e. 95 pickups still had
some 5.8's and the 3 trans options were
E40D, C6 & AODE. I thought they only
came with the E40D. I've got one of
those off my 95 351 Lightning motor
and maybe that'll even be the right one!
THANKS!!!!
4R70W behind 351W in pickup??? macx Transmission - Rearend 2 05-24-2005 09:19 PM
Ford Flexplate spacing k2mooch Transmission - Rearend 9 01-05-2004 02:51 PM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
