29 Coupe wheel well help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2012, 01:57 PM
Well I started to dig into the body last week. PO had the wheel wells covered in bondo and fiberglass tape. When I got down to the metal this is what I have to deal with. I don't have a lot of metal work experience but hey how do you get it if you don't start somewhere right. There was a newer inner wheel well panel sandwiched on the old rusty one. I know I will be replacing these on both sides. My question is where would you cut the panel to make the repair? At the edge (red) or up a bit (yellow). My feeling is cut higher up. Hoping I can use a shrinker/spreader tool to make this out of a piece of 90 degree sheet metal? As far as I know they aren't made anywhere. One more. I would like to remove my roof and separate the panels. I removed all the bolts and the nails in the pillars. Can't seem to get the roof off the body. Don't want to beat on it. I will be needing to make a good bit of metal repair on these where the roof and body meet as well. But that's a later post.
Thanks for any info.
Name:	DSC_0013_05 [50%].JPG
ID:	64928   Click image for larger version
Name:	DSC_0015_04 [50%].JPG
ID:	64929   Click image for larger version
Name:	Cut Here [50%].jpg
ID:	64930   Click image for larger version
Name:	DSC_0020_01 [50%].JPG
ID:	64931   Click image for larger version
Name:	DSC_0021_01 [50%].JPG
Old 04-23-2012, 06:57 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I would want to cut about where the yellow line is and make a neat cut in order to fit in the new metal..the roof and body is probably rusted together so you may need to use a sawzall carefully in the seam to get them apart..shrinker/stretcher is a great tool and needed for this sort of work as well as a beater bag and some hammers and slappers...Metal work is not all that difficult just takes patience and observation of how the metal works as you work it..Looks like some fun and you will fairly skilled by the time you are done with this project..
Sam
Old 04-23-2012, 11:49 PM
blwn31's Avatar
X2 as OneMoreTime stated.
Keith
Old 04-24-2012, 03:31 PM
Thanks for the replies. I have a buddy with a shrinker/stretcher so I will get it and start practicing on some 18 gauge. Never used one.
32 Ford 5 window coupe measurement needed TheCiscoKid Body - Exterior 1 12-15-2011 04:45 AM
60 Caddy Coupe wheel size question (and Brakes) Slomotion34 General Rodding Tech 2 06-27-2010 07:25 AM
'32 Coupe in a Weekend Warrior 5th Wheel Trailer? markha Hotrodding Basics 10 08-10-2009 09:05 AM
wheel info needed rmemech Hotrodding Basics 4 06-05-2006 06:39 AM
34 coupe , hidden headlights , any help needed Mrsipper Body - Exterior 1 09-25-2002 10:59 PM
