'29 Ford Model A Suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2005, 02:34 PM
I have a 29 Model A that I want to convert to a street rod, but I have a question about the front suspension. Is it possible (practical) to leave the Model A suspension as is and convert to disk brakes without killing myself the first time I drive the car? We plan on putting a 302 in instead of the stock 4 cylinder engine it currently has. Thanks for any help for this "rookie" hot rodder.
John
Old 11-28-2005, 02:40 PM
luckyscustomcreation's Avatar
a newbie all dressed up
i am building a 29 Tudor now and found that after the research that it was just as cheap to order a whole rolling chassis with all the components on it already. That way you start with a good platform instead of having to box the frame you got and the change all the suspension around. It worth the extra money in my book. just me 2 pennies worth
Old 11-29-2005, 08:51 AM
Frisco's Avatar
Glad To Be Here
John
You can leave the front suspension "as is" and still convert to disc brakes. Yes it is practical and much safer than the original stock mechanical brakes.
You CAN NOT leave the stock front radius rod "as is" if you wish to install any engine other than a Ford Model A, B or C 4-cylinder. You can leave the stock radius rod as is for the installation of a '32-'48 Ford flathead if you use a (modified to fit) '32 Ford 'K' member and early Ford transmission. For the installation of the engine you mention, you will have to either 'split' the front radius rod or go to hairpins or 4-bar system. The same would be true for the installation of any rear axle setup that would handle an updated engine.
The original frame should be boxed for strength for any updated engine.
Your original question gave me the impression that you want to convert your Model 'A' without removing the body from the frame. This can be done, but it is easier to take it down to the bare frame and go from there.
Old 11-29-2005, 11:10 AM
Thank you very much for your insight. You hit my question right on the head! I DO plan to take the body off the frame and box it as you recommend. Thanks again!
John
Old 11-29-2005, 12:14 PM
There are many frame manufacturers who do the Model A chassis in reproduction.....
TCI is one of the better known ones. They sell the above chassis for $860. All brand new, built in a jig with the proper spacings, a new front cross member and a rear cross member.....Which is vastly stronger that a old metal fatigued, welded on Stock Model A frame. When you take away the amount of money you get when you sell the rolling complete Model A chassis.......the TCI unit is almost free....
You can buy the chassis more complete.....as your pocketbook allows ( 32 Frame shown in red paint ).....or buy parts and pieces and progress as time and money allows.......which is how I did my last 32 chassis .( shown below )
This is a photo of the 32 Ford chassis I just did for my 32 Ford 3W coupe....and I used a set of original 32 frame rails.....and the rest is TCI stuff. I also have TCI suspension under my 32 Ford roadster ......shown in my avatar....
1951 Ford sedan- questions about fusion_ta66 Suspension - Brakes - Steering 1 10-04-2005 06:45 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
Model A ford project journal? deathbypontiac General Rodding Tech 1 09-15-2005 01:32 PM
49-51 Ford suspension jhenry Suspension - Brakes - Steering 7 12-08-2004 02:35 AM
mustang/pinto suspension on a model A 30coupe Suspension - Brakes - Steering 6 04-10-2002 08:47 PM
