Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 29 ford roadster
Old 03-19-2013, 06:52 AM
delawarebill's Avatar
delawarebill delawarebill is offline
top
u can also ck out some Tbuckets with tops and see the mounting we use.. its a T bracket that mounts to the side of the frame then attached to the top.. go to speedway and see the brackets. u don't need top framing but u will get air flow in the cracked area..
