29 model a tudor - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2011, 08:13 AM
29 model a tudor
I have a 29 model A, with a 2x3 3/16 custom frame,suicide front end,4" dropped front axle. Bought this car with the floor braces cut out, to channel the body. Previous owner said to weld 3/8 thick bar stock around the inside of the body,then weld square tubing to make a frame work to screw the floor panels to,didn't get a warm fuzzy with screwing the floor panels down,then to put bar stock and welt between the two frames, bolt the bar stock to the chassis, weld the floor frame to the bar stock. I'm sure there are many different ways to do this, so I'm looking for other options. Thanks Paul
Old 04-18-2011, 09:07 AM
Here's a link that show's one example of how it could be done. It's not on a Model A but still a decent example. http://www.rodandcustommagazine.com/...car/index.html
Old 04-18-2011, 01:31 PM
Irelands child's Avatar
An 'A' bolts through the floor board framework to the frame from the front to the rear with a separate 2 bolt bracket on each side just behind the cowl. There are wood blocks and welting to keep the squeaks and rattles to a reasonable level. I think what I would do is make up an interior frame similar to what was there originally, then build some floorboards for making the assembly reasonably solid. All this needs to be attached (welded) to the body for strength.
It sounds like you have a major project that really needs some "think through" if for no other reason then safety - yours.
Dave W
'31 Model A Tudor Sedan Rear Axle sgo70 Transmission - Rearend 5 07-07-2008 06:10 AM
31 Model A Ford Tudor RatsAss31 Introduce Yourself 3 07-28-2007 05:08 AM
1927 Model T Tudor Sedan nejnej99 Introduce Yourself 2 03-25-2006 05:35 AM
rear assembly for a 29 model A tudor jz29A Transmission - Rearend 4 02-15-2005 03:56 PM
filling a model A tudor sedan roof replay88 Body - Exterior 1 07-01-2002 02:57 PM
