29 A Tudor- Mustang II alignment - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2008, 07:18 PM
471A
After losing my 1930 A Fordor (built over the course of 22 years) to what began as an engine fire, I am (six years later) completing the 29 A Tudor atop the same frame, complete with a Progressive Automotive Mustang II cross-member. The front suspension employs 11 inch Granada rotors (ECI), two inch dropped spindles from Speedway Motors, and manual steering. These are, of course, all new parts, but match what I used in the Fordor, except that the Fordor used stock height spindles. The rebuilt A uses radial tires front and rear. Power is supplied through a Dana 60 rear, TH 350 transmission, and a 30 over SBC 350 with a 4-71 Roots, 800 cfm AFB, AFR heads, and MSD 6AL ignition.
My local shop suggests using the alignment specs for stock 1974-48 Mustang II. Thoughts ? From reading other Mustang II IFS postings, there seems to be consensus on 1/8 inch toe-in and camber in a range of 1/2 +/- 3/4. Caster suggestions, however, are all over the map, from 1/8 up to 6 degrees.
Old 06-13-2008, 06:25 AM
Bluejackets67's Avatar
Progressive recommends the following:
Camber: 0-.5 degree positive
Caster with Manual rack & pinion: 1.5 -2 degrees positive
Toe-In: 3/16"
stock mustang II on fendered 29 c_illes Suspension - Brakes - Steering 3 02-23-2007 05:18 PM
Alignment Specs Mustang II 2000jack Suspension - Brakes - Steering 11 05-27-2006 02:39 PM
Mustang II LCA alignment with crossmember? SinistrV6 Suspension - Brakes - Steering 13 07-31-2005 08:05 PM
Mustang II alignment values 5window Suspension - Brakes - Steering 11 01-12-2005 07:24 PM
Mustang II Home Alignment Ron M Suspension - Brakes - Steering 2 07-17-2004 11:08 PM
