#16
Just asking, as I have no experience with the XE284H cam: I am running a XE274H in my 383 10.3 static CR. It performs well for what I want. Would the XE284 be overkill on a street 350? I guess I am asking if my 383 is undercammed for strictly street use, or the XE284 would be overcammed on a 350? Register now (free) or login to remove ads |
#17
Honestly my build was quite cheap.And everything is new and will hold up to 450 plus horsepower just fine. Here it is
Engine block new 750 New Cast steel crank 180 New hypereutectic pistons 100 Piston rings 40 New Scat forged rods 225 Bearings cam,rod,and main about 75 Total for shortblock Just a little over 1400. That is with all new parts. with machine work to block and balancing I have just around 1800. You can get the same setup as mine and you would be happy with it. I did mine that way instead of the gm shortblock cause I wanted just a little more durability and hyperteuctic pistons instead of the regular cast. But you can get a gm l31 shortblock from skip white on ebay or from jegs or summitracing and its already put together for less then 1500 bucks. With a set of vortec heads from scoggin dickey with the added features and a edelbrock vortec intake you would have a really nice motor with the right cam. If you want streetability with some monster power get a comp xtreme engery 268h cam wich has 224/230 at 50 duration and good lift. You will get good power. I have a tired old vortec in my 96 s10 with everything stock except just an edelbrock intake and 600 performer carb nothing special and it runs good for being tired out and with only 200 to 250 at the most horse power. With the combo above you would have 350 horse power easy and get decent gas mileage with the right gearing and a 700r4 with overdrive. I like to put motors together with new parts. To me cranks that are undersized and rods that are redone are still worn put parts that will eventually fail from fatigue. I would go with the l31 gmshortblock build and go from there . That is the best bang for your buck and with cast pistons you will still be ok with 350 horsepower or so. Eric |
#18
Here is a link on ebay a brand new gm 350 l31 shortblock for 1295.00 and that is about the best price you can get. You can even go oem roller setup and get even more horsepower with a hydraullic roller cam. Its up to you just trying to give you some pointers. I would have gotten this setup if I did not have the extra that I cam up with and I am sure it would of been fun to run.
Eric |
#19
Agree, I can put em together much cheaper than that too. I think people look at the crate motors as convenience and they 'think' they are getting a good deal/motor because of the word crate and it comes as a long block. They are just too dam expensive though if you've built a few motors before. I have to agree with you there. For the price some of you guys build motors for.. I can build 2. |
#20
There is no such thing as too much cam. Just not enough motor. The XE284 makes more top end power than the XE274. No, its not too much for a 350. Favours the higher end of the usable "pump gas" compression ratio range. Wants a good bit of rear gear and converter stall. If all you do is cruise, then don't worry about it. Last edited by F-BIRD'88 : 04-18-2009 at 09:33 PM. |
#22
Do you have anything already. You can use your existing block if you have one and it's not bored .060 already. Go to the junk yard or engine core yard and buy yourself a block (with the intention to build). I pay $75 for any block I want ford/chevy/mopar etc. at core yard near me. Look at the blocks closely.. and pick the best one. Also look at craigslist in your area, again with the intention of looking for something to build. This may be a better route. I would look for something $200 or less. I say this may be a better route because you'll get everything (oil pan, pulleys, brackets etc).
Be careful how you spend your cheddar. You sound very new to this and before you know if.. you'll be out thousands and still on this board asking what to buy. It's not hard, find a good buildable block and start from there. Here are some additional considerations: Do you want early 2 pc main block Do you want late 1 pc main block (non roller) L31 block Do you want late 1 pc main block (with OE roller set-up) L31 block also All are good choices, but you may see the later blocks are a tad more expensive to build. If in doubt, bounce things here before you move. Good luck! |
#23
Check out these deals... goto the bottom of the page. 350 s/b $465.00
http://www.blainesmotorsupply.com/pricelist.pdf I just bought a 350 and a set of heads... talk to Sean. Great guys to work with. short block and heads look great. Building it as we speak. Tell Sean Fred sent you. -=Fred=- |
#26
Another suggestion, if you are inclined to a crate motor. Instead of the 290, you get the 330. A short block is about $700 more than the 290 and you get most of the goodies, a decent street cam with a good "lump" all the Vortech goodies etc.
I had the same decision to make ( and sorta still do) as I am planning on having the 330 installed next week (anyone want a deal on a decent 305?). My decision was based on the 290 was just a great street engine that was more than adequate, but blah, I have that now. Looked at the ZZ4 and said to myself, this looks good. A lot of bang for the buck and I'd have some bragging rights. The ZZ4 makes more horsepower, but only a little more torque. It's torque that spins the wheels and gets you going. It's torque that you feel (along with gravity) in your back when you step on it. Let's do some comparison: 350/290 350/330 ZZ4 HP: 290 330 355 Torque: 326 380 405 Without boring you with my $$$ thoughts, the 330 stands out as a bargain with a warranty at ANY GM dealer. |
| Thread Tools | Search this Thread |
| Similar Threads for: "290 HP GM performance long block" | ||||
| GM small block 307 V8 | rockthrower33 | Hotrodding Basics | 38 | 05-07-2010 06:46 AM |
| ok, here it is, for your projected hp level, do you need an aftermarket SBC block? | Pa Pa Dragger | Engine | 12 | 03-29-2009 11:12 PM |
| GM 1 piece or 2 piece 350 block | Carlos9 | Engine | 8 | 03-03-2009 11:22 AM |
| 350 long block worth | crshrmn3 | Engine | 1 | 10-01-2003 11:54 AM |
| Where can I obtain factory GM block blueprints? | Blownolds | Engine | 3 | 08-09-2003 11:47 PM |
