292 From 64 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2010, 09:03 PM
292 From 64 Ford
ok, got a parts truck a 1964 Ford F100 for 50 bucks. It aint in bad shape but as a first timer at tearing down any engine I was curious what others opinions are in tearing down the 292 in it and adding a few performance parts while re building.
Old 11-17-2010, 09:11 PM
techinspector1's Avatar
Wiki Edits: 326
While the Y-block Ford is a rather pretty motor to look at when dolled up with finned rocker covers and such, it is just about the last motor on the planet that I would spend money on to try to make it fast due to the lackluster heads.
If I were going to add some juice to it, I'd probably do it with a blower, because a blower doesn't care what the heads flow like, it just pushes the air through them regardless.
If you want to go fast with the truck for the least amount of money, transplant a 460 into the engine bay.
Replacing the Timing Chain '64 Ford 390 Billy Boy Engine 14 12-26-2011 07:02 PM
Ford 292 to '39 trans Youngster Transmission - Rearend 1 08-22-2007 05:31 PM
Starter Rotation for 57 Ford 292 Y Block bhunter21 Electrical 3 08-18-2005 02:58 PM
64 ford willie1010 Engine 1 05-10-2003 12:50 PM
460 Ford into 64 Tbird birdman Engine 7 10-09-2001 08:37 AM
