292 cam on airboat direct drive - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2011, 09:47 AM
putting an inline 292 on airboat. prop will turn 3000 max. if I spent money got a cam made. how much could I increase horsepower at 3000. Would it be 10 horse power or more. maybe horsepowr is not the hole ball of wax. maybe its torque. any thoughts.
I know you can get lots of horse power by increasing rpms, but don't have that luxury.
Old 05-27-2011, 03:02 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
F-bird... that's a fine idea, but airboats like to explode props above about 3000. He's limited to about 3000 prop RPM.
If you're intent on sticking with a direct drive, your engine needs to peak its HP at 3000. That means a tiny cam. If you increase your HP at 3000 rpm, then you will (like F-bird says) increase prop pitch to keep it at 3000.
For the most part, direct drive applications that want more power require more cubes. The best way to increase torque (and consequentially HP) when the RPM limit is fixed is to increase displacement. That's why most direct drive airboats use big blocks. Most small block airboats with big power need to use a reducer gearbox. That way you can spin the engine to 5000 and make nice power while maintaining safe prop speed.
Old 05-27-2011, 03:43 PM
techinspector1's Avatar
Wiki Edits: 326
A gearbox is the first thing that popped into my mind. Heck, set it up with a 3-speed manual trans (low buck) and run it in second gear. You could also run it in first gear for low-speed, high-torque. Or run it in reverse to back up. "Hey dude, check it out, my airboat backs up". Build the motor at 9.5:1 with a tight squish and Crane 204541 cam, 216/228, 112, 0.530"/0.560" power range 1800-5400.
http://www.summitracing.com/parts/CRN-204541/
For coming right off the crank to the prop, the stock cam will probably produce the best torque numbers at 3000.
Old 05-27-2011, 03:48 PM
crowerjunky's Avatar
JOHNNY
call dave at waterthunder performance his site is www.waterthunderperformance.com
Old 05-27-2011, 06:28 PM
Banned
Make the tq curve run parallel to the prop efficentcy curve, whil making it as high as you can under 3000prm.
Old 05-28-2011, 07:31 AM
curtis73's Avatar
Wiki Edits: 16
Originally Posted by techinspector1
A gearbox is the first thing that popped into my mind. Heck, set it up with a 3-speed manual trans (low buck) and run it in second gear. You could also run it in first gear for low-speed, high-torque. Or run it in reverse to back up. "Hey dude, check it out, my airboat backs up". .
I had a similar idea, but it involved a powerglide
Old 06-02-2011, 11:16 AM
thanks
Thanks for the replys, I thought about a gearbox (reduction drive) Right now I am running a 250 inline it does surpriseingly well. I have a 292 on the garage floor and ready to put in boat. will post video one day. I do have an adjustable pitch prop. currently set were it turns max 2600 rpm.
Direct Drive Gears. afsog Engine 25 11-08-2010 01:47 PM
Direct drive, converter only, no gear box Augusto Transmission - Rearend 24 06-21-2010 01:09 PM
Direct drive or Belt driven mikeweb Garage - Tools 18 07-16-2007 11:09 AM
a500 no reverse or direct drive when hot dgm Transmission - Rearend 0 04-29-2006 06:34 PM
Direct drive crank driven supercharger. Super Chevy Engine 10 04-18-2006 05:47 PM
