Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 292 chevy l6
Thread: 292 chevy l6
Old 06-16-2010, 10:22 AM
CNC-Dude CNC-Dude is offline
Originally Posted by QParker
Can anyone recommend a mild cam for the 292?
How would the Clifford 264 cam be? Here's the specs on it:
*Our 264 cam is ground at .206 @ .050 with a big valve lift os .518. This is .112 higher valve lift than stock. Stock being .406 valve lift.
That Clifford cam is a good one, but you'll still be a long way away from your goal of 300 HP with it. You will also have to do some pretty extensive head work also to help get you to your goal HP as well. A Clifford intake will also be helpful, the Offy intake will fall short of getting you there also. A set of long tube headers with 1-5/8" primary tubes will help too.
