I was recently involved in a very thorough 292 dyno test over on Inliners. We tested (8)different cylinder head combos in various stages of porting and valve sizes. 300 HP will be very easy for you to achieve. We started with a bone stock 292 to establish a baseline, and even in bone stock trim(160 HP) yielded 300 ft. lbs of torque right from the 1800-2000 RPM on up in a straight line across the RPM range. All of these tests were done with a "pump gas" compression ratio of 8.8-1, and all parts were off the shelf components. The best HP combo was with a Clifford intake and a 4 bbl Holley carb, and all combos were still easily streetable, this combo also yielded 330 ft.lbs also. Stroking isn't necessary, and any rod other than a stock one is going to have to be custom($$$$), since it shares absolutely nothing in common with any other engine to do a swap with. Plus the bearing journal overlap on the crank is not very good on the stock crank anyway, and stroking it is only going to reduce it futher. I've built many of these engines for Comp Eliminator guys and have made over 600 HP with the 292 N/A, so you have plenty of power potential without having to stroke it. There is a guy on Inliners right now that has a Turbo 292 in his race truck that makes over 700 HP/800 ft lbs of torque, so there is plenty of ways to go to get power out of these engines.
The main key to power in these engines is in the head prep. You will have to consider large valves(1.94 intake) and removing the intake port bolt bosses and installing some bolt-in lumps. You can easily increase the flow from the stock port with 160-ish CFM with a 1.72 valve, to around 270 CFM with a 1.94 valve by doing this simple modification. Race heads can be made to flow 330+ CFM with even larger valves and more aggressive porting. Last edited by CNC-Dude; 06-14-2010 at 10:16 AM. |
As CNC said and as you'll read, the trick, or at least a big trick is in the head. Years ago we were happy with taking out the boss in the middle of the intake passage. As you'll see in the book, Kay Sissel came up with a gadget to change the contour of port floor to give a better entry on the short side radius to the valve. Always think of the piston as part of the combustion chamber as with any engine build. Squish and quench are friends that let you run more compression per octane of fuel you're buying. While a lot of configuration details come into play making it hard if not impossible to predict the engine's ability to control detonation, the general rules are to keep the squish/quench deck with a steel rod in the range of .040 to .060 inch at TDC. If you need to increase volume above the piston use a piston that is dished only under the valve pocket, do not use pistons with circular dishes. If you can, use a flat top piston, if you must reduce chamber volume use a dome but as little of that as possible. If you use a domed piston, Singh slots cut into the piston rather than the head are useful for getting the flame front over the dome. 300 hundred horse from a 292 is easy to accomplish. Once the head and piston selection is set up, like any-other engine, it comes down to the cam, carbs and exhaust. balance and damping on the front of the crank are important to get an inline to live a long time at high power outputs. In line blocks are not as stiff as V design blocks, so keeping odd moments of inertia from developing on the crank to be transmitted thru the bearings into the block is an important undertaking for long term reliability. In lines tend to be sensitive to crank harmonics, so damping of vibrations is of significant importance. Bogie |
Can anyone recommend a mild cam for the 292?
How would the Clifford 264 cam be? Here's the specs on it: *Our 264 cam is ground at .206 @ .050 with a big valve lift os .518. This is .112 higher valve lift than stock. Stock being .406 valve lift. Last edited by QParker; 06-16-2010 at 03:50 AM. |
the 292 had the et record for I-6'ers in the late 60's and early 70's. built in durant okla. by mr. self.some of the older folks will remember him.he started with the chevyII and later went to the camaro. they were dang fast.
I am going to lump port the head, install 1.94 int. and 1.50 exh. valves in it.
How would the solid lifter "EP-22/25" cam work? Here it is: http://www.englecams.com/downloads/...gle_catalog.pdf |
How much power could I get from the 292 while still keeping it streetable with a mild cam and keeping the RPM's below 6000?
Everyone talks about HP, but if I have a 300-350HP 292 what would the torque be? That's what these engines are famous for, Right?! |
One of the best combos we recently dynoed made 330 Ft Lbs of torque and was 300 HP. The RPM was well below 6000. The torque curve was almost a straight line from 2500 to 4200 or so. I looked at the Engle link, but didn't which grind you were meaning specifically. I'll look back at some of the dyno sheets and see what cam we used for the best peak HP and TQ #'s we got.
I just posted one on Craigslist ?
cnc 292 N.A.=600 hp?
| List all of your cars HERE! | Carbed95GT | Hotrodders' Lounge | 289 | 11-09-2011 06:43 PM |
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| Hi. just wondering why the 350 chevy small block is so good... | judgedredd | Hotrodders' Lounge | 78 | 06-25-2010 08:01 AM |
| small block big block weight difference | Jmark | Engine | 3 | 02-04-2008 12:21 PM |
| Chevy 292 Timing Question | BIG292 | Engine | 9 | 07-29-2007 09:58 PM |
