Thread Tools Search this Thread share on Facebook
  #1
Old 08-24-2011, 07:38 PM
PureC4 PureC4 is offline
Last journal entry: more...
292 ci six.... Good or Bad Thing?
Finally Id the motor it's a 292 six between 63/72. I know nothing about these motors except that I read they were built for the trucks and had a taller deck... So please chime in as to weather its worth working on or switch to a SBC. I dig the looks of the inliner, but is it going to be trouble. Wanting to build a driver.... thanks Also how do I ID the trans?
Register now (free) or login to remove ads
Old 08-24-2011, 07:45 PM
Blazin72's Avatar
Blazin72 Blazin72 is online now
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The 292 is a great engine. What would it be going in? Heck, it's nearly the same size as Fords 302 and Chevys 305
Old 08-24-2011, 08:03 PM
It's in a 54 3100 pickup, has an offy 2x1bbl carb intake
Old 08-24-2011, 08:30 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Cool deal.. www.inliners..org
Sam
Old 08-24-2011, 08:51 PM
Blazin72's Avatar
Wiki Edits: 19
Keep the 292! It would be great in that truck!
This would look cool:
Old 08-24-2011, 10:07 PM
Dogbreath077's Avatar
Dogbreath077 Dogbreath077 is offline
Old School Motorhead
You can take advantage of the I-6 torque over the V-8 by balancing the engine, porting the head, bump the compression a little, free flow the exhaust, and install a larger carb or a multi carb set-up. The overall weight will be less than a V-8, so your power to weight ratio will be better, you are starting out with more torque due to the inline config, so breathing better, and higher compression will make for a very nice hot rod.
Old 08-25-2011, 05:04 AM
Irelands child Irelands child is online now
The only things wrong with that engine is trying to find someone who still knows much about them. And of course the price and easy availability of speed parts.
Then a sweet dual exhaust with a set of glass packs - your truck will NEVER be identified as having a belly button engine
Old 08-25-2011, 06:27 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
The 292 will certainly have a nice rapping exhaust note to it with hot rod pieces. A gent I knew who`s now deceased was a logger in his early years.
He was a 100% pure bonafide Ford man. But he would often say "Chevy only made one good engine and it wasn`t the small block, it`s the 292 Straight six. I had one in my pulpwood truck when I was still logging. It was the hardest pulling engine we had, even more torque than the V8`s of the later trucks plus it was dead set reliable. Miles in the woods, forest trails, low gear, high RPM trip for several miles back to the highway with a full load of logs. She never ran hot, never broke down, she wouldn`t struggle to haul a full load of logs up a steep hill. Best of all, maintainance was a breeze"
Old 08-25-2011, 09:05 AM
oldbogie oldbogie is offline
Pick up a copy of this book "Chevrolet Inline Six-Cylinder Power Manual" by Leo Santucci. It gets way into the nitty-gritty of making the GM inlines into going machines.
The 292 is the best choice to hop up because the raised deck provides better head bolt bite than the lower deck blocks. The low deck blocks have a habit of either pulling the threads or cracking in the corners when those bolts are cinched up real tight.
Bogie
Old 08-25-2011, 02:16 PM
willowbilly3's Avatar
willowbilly3 willowbilly3 is offline
Last journal entry: Body mods
I have seen several 292s hot rodded over the years and they work out pretty well. Just keep in mind that they are a gas hog and don't get better when you hotrod one. Personally I'd go with the 250, same basic engine except for a shorter block and they were good on gas.
Old 08-25-2011, 03:43 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Location: In da woods, Union County, North Carolina, USA
Wiki Edits: 326
I've owned several Chevy pickups with the 292/4-spd in them and always thoroughly enjoyed driving them.
Stay modest on the cam, this is not a high-winding motor that you want to buzz to the moon. It also is a low static compression ratio motor, so will not run well with too much cam. Usually, the first cam offered for the motor in the manufacturer's list of cams is the one you want for a street-driven truck. If you're looking for a lumpy idle, then tear the motor down completely and build it with more static compression ratio (piston change) so that it will match up with a stronger camshaft. 2 or 3 one-bbl carbs along with long-tube, tuned header(s) will wake it up.
In my opinion, six cylinder motors sound sucky with an automatic transmission.
To really enjoy the truck, true the flywheel, install a Centerforce diaphragm clutch and completely rebuild the clutch linkage with all-new pieces oiled well. If using a column-shift linkage with a 3-spd trans, also remove all linkage pieces and rebuild with new, well oiled components. When everything works like brand new, you will want to drive the truck more.
Old 08-25-2011, 09:07 PM
junker junker is offline
292 engine
Keep in mind, this is the heavy duty truck engine. It was not intended to be a high rev piece, a lot of the 194/230/250 parts will not fit. It's similar to the old 302 "Gimmy" truck engine in regards to it's limitations. Proper gearing, and not going overboard with camming, and carburation, instead concentrating on it's torque curve will make a fun driver. However, revs will not do it, neither will modifications enhancing it's rpm limit.
Old 08-26-2011, 04:35 AM
Most of my big six wrenching experience is with the 300 Ford but some of the same basic principals apply. As mentioned those engines were designed for torque and that is where their true function is best. I have a Comp 260 cam in my 300 and would gladly go back to a stock cam because it lost some of it's off-idle grunt.
With the 300, the best torque and mileage cam is the one they came with or an Isky Mile-a-more.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "292 ci six.... Good or Bad Thing?"
ThreadThread StarterForumRepliesLast Post
Need a good shopvac, not like the lousy thing I have from SearsBinderDriverGarage - Tools2404-04-2010 11:10 PM
Why the economic crisis could be a good thing.ChevyThunderOff-Topic1502-03-2009 06:48 PM
Is this a good thing or a bad thing?Rob KellerOff-Topic404-30-2007 09:54 PM
16.00 Volts...Too much of a good thing?HUH?Electrical603-17-2007 04:55 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
