Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 292 Turbo Head
Thread: 292 Turbo Head
Old 12-09-2003, 05:58 PM
NAIRB's Avatar
NAIRB NAIRB is offline Moderator
292 Turbo Heads
The 292 "turbo" head was the first generation, over the counter racing head offered by Chevrolet for the small block. This is a very good cylinder head, but generally needs to be ported to serioulsly out-flow a comparable "double hump" type head.
So, the answer to your question is this, if you've got stock type open chamber heads now, the 292 turbo heads will give you a performance increase, if you are capable of doing some good pocket porting, they are easy to get some big air out of them.
A little outdated, but still a good head.
