292H comp cam with vortec heads
I have a set of modified Vortec heads, with 292H comp cam the guides have been cut down so It can handle up to a 550 lift cam, and the heads also have been ported and polished, and screw in studs.
I wanted to know have any of you guys ever ran this cam before how did you like the performance out of it, and what are some of the downsides of running this cam. the motor is going in a 84 Z28 with 3.73.. if you could recommend any other cam that would work best with my head's what would you recommend?
the motor is at 10:1 compression and it's a 350 bored over .40.
all responses are highly appreciated
