Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 292H comp cam with vortec heads
Old 11-19-2012, 04:55 PM
ap72 ap72 is offline
Banned
XE274 and NO BIGGER. Smaller would actually be a little better.
You can go with the 292H but you'll make less power and burn more fuel- it's a losing proposition all around.
the 401A3 by lunati is also a good cam to use if you want to use a solid flat tappet, I'd definitely go solid on this route.
If you can afford a roller cam it gets even better.
