Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 292H comp cam with vortec heads
Old 11-19-2012, 05:38 PM
hcompton's Avatar
hcompton hcompton is offline
Old & Furious
Originally Posted by vinniekq2 View Post
moderate cam for someone that is serious
Yeah that is a nice cam. Not sure why everyone says its too big. Its made for radical street motor. Not a race cam but easily good for bracket or weekend racer. I always thought the 294s was one of the best cams had if not the best. But that is solid lift. The hyd. Will run nice as well.
After market alum. Heads would be better for that cam but i dont see a reason it wont make good power if the heads have good flow. Not allported heads flow the same. Many are the same or only a little better than stock. But good flow high compression large cam sounds like you got the bases covered.
Hope your ready for a lumpy cam. Xe cams run a little smoother but just dont seem to last in the larger grinds. If you want a smooth idle from large dual pattern cam go roller.
