And judging by what I see, the XE268H ain't that bad, either. Especially w/the mild gears and stall. Comp's dyno sheet has it down for 342 HP @ 5000 RPM and 413 ft/lbs @ 3800 RPM using Dart S/R's and a 3310 Holley. Probably long tube headers too. Manifold Vacuum is 15.5" Hg @ 800 RPM & 17" Hg @ 1000 RPM w/ no load. BTW, Comp also has a dyno sheet on the XE274H, it shows 369 HP @ 5900 RPM and 410 ft/lbs @ 3900 RPM using same parts as above. Manifold Vacuum: 11" Hg @ 800 RPM & 14" Hg @ 1000 RPM w/ no load. Get this one ground on a 108 LSA... The rest of their cams w/dyno sheets are here. |
My 2800 car (with me in it) ran trapped at 120mph in the 1/4 mile with a 292H, 200cc dart iron eagles heads, 10.5:1 350, full length headers, rpm intake, and a 3310 750 holley. 3.90 gear and T5 manual trans
That is 370 hp at the tires beat the hell out of that engine for 10 years. cam finally when flat when they changed the oil formulation |
Personally I never run "shorty" headers- do what it takes to get it right.
F birds "Y" pipe is interesting, reminds of the Tri Y headers I dyno'ed the Tri Ys! The increase in hp and torq was quite a bit more then street headers and fell just short of tuned competition headers till they entered higher rpms! over 5500rs! I guess that works on the same principle for scavenging!
I never ran shorty's either. Jester |
My dyno tests were in the the mid 80s! But they were really popular in the mid 70s and early 80s here! and are still produced! they were also used on a lot of Honda 750 racing motorcycles! Jester |
Well not really the same as a tri Y.
The Idea of joining the two banks together with this Y pipe is 1. It fits the car. A 2 into 1 exhaust system fits this specific car much better. 2. to make the total system exhaust system scavedging a lot better. (more mid range torque) The engine sees it as of the header primarys are longer than they are. |
292
![]() your 84 z will be happy without a little low end.. unless oh course you've reworked the whole car.. the facory set up.. a weak v6 with iroc wide tires can turn them over.lol the car will be faster on the street with a softer lower end, that'll get you moving, roasting tires=fun but not fast |
runs mid 11's at 120. Being a manual shift and a weak t5, I shift the gears slow. however, runs mid 10's at 135 with I use the 150 to 200 no2 shot. 6.9 at 110 1/8 mile on n02. 71 240 zcar (datsun)
Starting with the right tires. You can put all the torque to the ground and leave your combo in the dust on acceleration. You cannot make a car faster by killing off power. Like overcamming it. The big top end will not be realized with the 292H with this exhaust system. My car will yank the front wheels of the ground from a light in all street trim. The way I run it at the track is the same as the street setup. Its just that the track is the right place for that. You want to put garbage tires with no traction on your car go ahead. You will never make up the difference. you do not want to or need to kill off low mid grunt. You just need some basic traction. this car weights almost 1000 lbs more than a 240Z w a SBC and 4 speed. |
love to see a vid of it hanging tires on the street, on dot tires so a 240z is 2200lb's? |
| Tags |
| 292h, comp cam, vortec heads, z28 |
| Vortec Heads with 292h Comp Cam | stackitup_91 | Engine | 29 | 10-19-2012 02:43 PM |
| sbc Pro Comp vortec heads any good? | TheCiscoKid | Engine | 13 | 10-18-2012 03:31 PM |
| 355 vortec heads comp xe268 build questions | TX512 | Engine | 6 | 11-30-2009 09:07 AM |
| Will a comp cam 26918-16 behive fit vortec? | david ahluwalia | Engine | 6 | 03-10-2009 08:57 PM |
| 292h cam gas? | 1967chevelle454 | Engine | 11 | 04-03-2008 05:27 AM |
