292H comp cam with vortec heads - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-20-2012, 02:45 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: 360 mopar
2,355 lbs (American) Datsun 240 Z. F birds close enough!!
Jester
  #32 (permalink)
Old 11-20-2012, 04:59 PM
F-BIRD'88's Avatar
Yada Yada Yada
Originally Posted by 454C10 View Post
runs mid 11's at 120. Being a manual shift and a weak t5, I shift the gears slow. however, runs mid 10's at 135 with I use the 150 to 200 no2 shot. 6.9 at 110 1/8 mile on n02. 71 240 zcar (datsun)
It would run
12.40's@111 in the third gen car (3530# wdriver)
  #33 (permalink)
Old 11-20-2012, 05:10 PM
Originally Posted by F-BIRD'88 View Post
It would run
Thats quick!
Jester
  #34 (permalink)
Old 11-22-2012, 08:11 AM
a 240z is 2400lbs with fuel, I added another 200lbs with bigger stuff (engine, trans, exhaust, tires, radiator, diff, no2 system......) Plus I weigh in about 200lbs. So 2800lbs total car weight with driver. et is a little slow as compared to the trap speed due to slow shifts
292h, comp cam, vortec heads, z28
Vortec Heads with 292h Comp Cam stackitup_91 Engine 29 10-19-2012 03:43 PM
sbc Pro Comp vortec heads any good? TheCiscoKid Engine 13 10-18-2012 04:31 PM
355 vortec heads comp xe268 build questions TX512 Engine 6 11-30-2009 10:07 AM
Will a comp cam 26918-16 behive fit vortec? david ahluwalia Engine 6 03-10-2009 09:57 PM
292h cam gas? 1967chevelle454 Engine 11 04-03-2008 06:27 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
