2970126 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2009, 09:38 AM
2970126 heads
i have a set that are pinned rocker stud comp cam roller tip rocker 1.52 ratio with comp springs what is the max lift cam i can use ? right now i have comp cams magnum12-242-2 280/280 480/480 with 110degree seperation.. i would like to go bigger they are on a 74 350 .040 all forged lower end i want to make as much power as i can out of the stuff i have.. i dont mind doing the work its fun
Old 07-22-2009, 09:51 AM
SSedan64's Avatar
Those 3970126 have tiny 1.72" Intake valves, you're wasting your time.
Old 07-22-2009, 11:58 AM
DoubleVision's Avatar
SS Called it right. The small 1.72 intake valve coupled with a smallish intake runner was made for high torque at low RPM. The powerband of these heads are over at 3500 RPM.
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 04:50 PM
Which Heads to use? Mike_82 Engine 9 03-05-2009 11:32 PM
sbc heads shieldbreaker Engine 5 08-27-2005 09:12 PM
Heads and Intake combo black66 Engine 4 07-24-2005 12:33 AM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 02:16 PM
