2k clearcoat advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2009, 06:33 PM
2k clearcoat advice
hi all this seems to be the biggest source of great painting info im in the uk
and iv been using upol system 20 2k clearcoats now im finding this buffs great after wet sanding but i find it hard to apply it sags easy and seems to take a long time to flash off between coats.
iv painted a fair few cars in my time but this one needs to be a1 for show use.
its air dry not in an oven i want to get a good coat to flat down and im thinking is there a better brand of clearcoat i could be using? im not sure the upol stuff is all that great
any help would be great its a bit thin in the uk
Old 04-18-2009, 08:56 PM
I hve never used this product, but typically if the clear is running you spraying it on too heavy and not giving it enogh dry time. If it is taking too long to dry get a reducer designed for a lower temperature.
Old 04-18-2009, 09:34 PM
302 Z28's Avatar
I had fantastic luck with PPG DCU2002, and I'm no professional. You just about have to keep your gun still to get a run. The learning curve with this clear is very short. As you start using it you get more comfortable with it. It is a very durable long lasting clear. It's best to wet sand and buff within a week of application or the clear will get as hard as concrete and be a real bear to cut and buff.
Check the link at the bottom of my sig and also take a look at my photo album for the results.
Vince
Bare Metal Mollard Body - Exterior 71 09-25-2008 02:48 PM
Advice on appying acrylic clearcoat for newcomer!! ourkid Body - Exterior 5 11-25-2005 05:28 PM
Filler after 2K primer question rcm800 Body - Exterior 8 11-15-2005 01:09 PM
2K applied, still need some filler - ?????? GRN69CHV Body - Exterior 2 10-23-2005 07:48 PM
Question about epoxy over 2k misteryu Body - Exterior 4 08-31-2004 05:59 PM
