Thread Tools Search this Thread share on Facebook
  #1
Old 07-02-2011, 11:03 PM
flips712 flips712 is offline
2K Clearcoat sprayed - Do I cut and buff?
I'm painting a few plastic pieces in my car's engine bay. I just finished spraying a 2K clearcoat by SprayMax. Everything looks very shiny and glossy. Is it necessary to cut and buff the clearcoat now? If so, should I wetsand then use rubbing compound or just use rubbing compound?
Thanks,
flips712
Register now (free) or login to remove ads
Old 07-03-2011, 06:27 AM
freethinker52 freethinker52 is offline
Thanks,
flips712
its not necessary if you are happy with the result.
Old 07-03-2011, 01:01 PM
Will cutting and buffing it make it shine more? And how do you do it? After you wetsand it do you apply rubbing compound? Or do you need to spray more clearcoat after you wetsand it? Is the clearcoat stronger if you don't cut and buff it?
Thank you,
flips712
Old 07-07-2011, 12:59 AM
hector.paz1 hector.paz1 is offline
All the right answers
You said it all you can wet sand it but good luck trying to melt back on some small pieces but then u will have to rub it out by hand. To make it cherry u said it sand it with 600 wet and then reclear the pieces. That is how u will get show results but remember clear is the most expensive thing sometimes.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "2K Clearcoat sprayed - Do I cut and buff?"
ThreadThread StarterForumRepliesLast Post
Best supplies and process to Cut and Buff CLearcoat67ElcaminoBody - Exterior805-04-2011 09:56 AM
Spray clearcoat over clearcoat, should I sand first?klingfilmBody - Exterior410-14-2009 05:36 PM
Help epoxy primer sprayed?brandonA.Body - Exterior610-01-2009 02:26 PM
to much sprayed gasburnt oldsEngine005-27-2008 11:07 AM
Can PPG MP170 be sprayed on this?satexasf150Body - Exterior810-22-2005 06:07 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
