2k Epoxy - thinning - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2007, 04:09 PM
2k Epoxy - thinning
I'm going to use one of those Preval Sprayers to cover some bare metal with 2k epoxy. Can I use acetone to thin it a little? or maybe use some paint thinner?
Old 02-13-2007, 06:42 PM
What brand epoxy are you using????
You should use the recomended reducer.
Old 02-13-2007, 07:01 PM
KFP305-QTGray 2K ISO-Free Primer
Old 02-14-2007, 12:08 PM
Countilaw's Avatar
Cox Custom Cars
I've used Acetone in cold weather and it works well. You shouldn't shoot 2k in weather below 55 degrees. The warmer the weather the faster the acetone flashes out.
I've also used a slow urethane reducer. it allows the 2k to flow out smooth and flashes off at a good rate like you would want with a sealer.
Old 02-14-2007, 12:10 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Definitely get some of the proper reducer for that and use it...Just asking for issues by playing chemist..Check with your jobber or supplier..
Sam
Bare Metal Mollard Body - Exterior 71 09-25-2008 02:48 PM
Epoxy over 2K and on polyurethane??? Mustangous Body - Exterior 11 01-06-2007 08:32 PM
2K Aerosol epoxy., urethane primers AND clears!! MARTINSR Body - Exterior 8 11-10-2006 08:45 PM
primer question 347mustang Body - Exterior 3 07-05-2005 09:17 PM
Question about epoxy over 2k misteryu Body - Exterior 4 08-31-2004 05:59 PM
