Hotrodders Bulletin Board
#2
re: 2k mar-hyde primer
It will thin down when you activate it but if at that point you still want to reduce it, you can use any urethane reducer.
#3
I use to use that primer, it's the thickest stuff out there.
I thinned it a lot, up to 100%,(probably too much), but never had a problem. But that's probably due to me letting it cure 48 hours or more before top-coating. It did have a problem settleing out in my gun when thinned. I used the DeVilbiss bag system and would lay the gun on its side beteen coats, or else it would clog the gravity feed gun when thinned a lot. Good primer though, I used a lot of it and it did great. sure is thick though. ![]() |
Back to top |
Similar Threads for: "2k mar-hyde primer"
| 2K aerosol can filler primer review. | MARTINSR | Body - Exterior | 15 | 09-05-2008 09:59 PM |
| Maaco vs. At-Home Paint Job | nightrain_rod | Body - Exterior | 108 | 06-25-2008 04:37 PM |
| Filler after 2K primer question | rcm800 | Body - Exterior | 8 | 11-15-2005 12:09 PM |
| 2k Primer scraping off? Need help | misteryu | Body - Exterior | 1 | 07-17-2004 04:55 AM |
| Mar hyde vs omni primer | 51f1vee8 | Body - Exterior | 2 | 07-31-2003 07:21 PM |
