2k mar-hyde primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2008, 01:11 PM
2k mar-hyde primer
what reducer to use with the 2k mar-hyde primer. i've got about a half gallon and it is thick.
Old 12-01-2008, 02:12 PM
BarryK's Avatar
It will thin down when you activate it but if at that point you still want to reduce it, you can use any urethane reducer.
Old 12-02-2008, 06:15 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I use to use that primer, it's the thickest stuff out there.
I thinned it a lot, up to 100%,(probably too much), but never had a problem.
But that's probably due to me letting it cure 48 hours or more
before top-coating.
It did have a problem settleing out in my gun when thinned.
I used the DeVilbiss bag system and would lay the gun on its side beteen
coats, or else it would clog the gravity feed gun when thinned a lot.
Good primer though, I used a lot of it and it did great.
sure is thick though.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
2K aerosol can filler primer review. MARTINSR Body - Exterior 15 09-05-2008 10:59 PM
Filler after 2K primer question rcm800 Body - Exterior 8 11-15-2005 01:09 PM
2k Primer scraping off? Need help misteryu Body - Exterior 1 07-17-2004 05:55 AM
Mar hyde vs omni primer 51f1vee8 Body - Exterior 2 07-31-2003 08:21 PM
