2k primer lifting problem.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2012, 01:52 AM
prostreet6t9's Avatar
Differential/Driveline
Using 2K Primer on a NEW 68 Camaro rear spoiler.. When I go to block sand the spoiler I've been getting 2 or 3 spots that the primer actually lifts and didnt adhere. I block sand the spoiler down and feather out the spots that lifted and spray again.
Then I'll get at least 1 spot that will lift again and in a different spot. The spots are usually 1" or 2" in Diameter. It's happened 4 or 5 times now and I'm getting stumped on this one.
Any Idea's??
Old 09-30-2012, 11:22 AM
mitmaks's Avatar
Last journal entry: Grille
Can you post a picture? Sounds like paint underneath is not dry and solvent in primer just lifts it when you shoot it.
Old 09-30-2012, 11:26 AM
Lifting is caused by solvents getting UNDER the substrate. That spoiler must have a poor quality primer on it already. It was either poorly prepped so the primer is just "laying on top" of the spoiler so when you apply more primer over it the solvents from the new primer get under that primer because it isn't sticking well to the spoiler, and it lifts it up.
Or, the primer that is on the spoiler is 1k or poor quality 2k and when you spray your primer over it the solvents go INTO the poor quality primer because it is "soluble", lifting it.
You can strip it all off, you can spray your primer dryer so it's solvents flash off before they can be soaked up.
Sand with a finer paper feathering out these problem areas is also often a fix. If the feathering is done with a finer paper there aren't scratches that allow the solvent to get thru.
Old 09-30-2012, 03:35 PM
Here is the last pic..
Name:	messed up spoiler.jpg
Old 09-30-2012, 03:53 PM
MARTINSR.. This thing is kicking my butt.. You think I need to strip it all the way down and start over?
Old 09-30-2012, 04:55 PM
Seldom does something need to be completely stripped, it has some problem areas and you sand those out and proceed. But if it's crappy product you are spraying over, yeah it needs to be removed.
Having problem with epoxy primer...... onebadmerc Body - Exterior 22 05-19-2011 02:31 PM
Primer lifting. Coaner Body - Exterior 3 05-11-2011 09:02 PM
Primer problem daz59 Body - Exterior 3 05-16-2008 07:10 PM
Poly primer problem. beemdubya Body - Exterior 9 04-05-2005 09:31 PM
primer surfacer problem 6speedwagon Body - Exterior 2 04-30-2004 05:50 AM
