-   -   2k Primer spray problem (http://www.hotrodders.com/forum/2k-primer-spray-problem-232584.html)
vespa2go 05-05-2013 10:10 PM
dear friends
I always used 1 K [rimer, but I used this time 2 K primer: ratio 1 part: 1 part catalyst. The primer dried extremely fast at first layer, but second layer it makes some king of garnule and powder once dried... when you toiuch it, the primer become a kind of yellow powder at the surface, almost like primer dried before reaching the metal... I need to wet sand it now grrrrr.... what did I do wrong?
I suspect my spray gun setting or can do I need (or can) add more reducer??
thks
33Willys77 05-06-2013 06:37 AM
What product are you using. Are you sure its 1 part primer to 1 part catalyst? Wow, that is a lot of catalyst - usually 4 parts primer to 1 part hardner (might be some variations with different products). I am thinking your mixing ratio is WAY off.
mitmaks 05-07-2013 06:29 PM
You need to follow product data sheet.
jpmillermatic 05-07-2013 08:09 PM
I agree w/33willys77....
double check your ratios for the 2K stuff, it might be different than what you are used to....
sounds like its drying way to fast.....could be a clogged setting on the gun, plugged or restricted siphon feed, ect....
JP
TucsonJay 05-07-2013 08:49 PM
No reducer????????
Lizer 05-08-2013 03:37 PM
I've never used a reducer with 2k's I have used.
TucsonJay 05-08-2013 03:52 PM
Interesting. What brand is it?
Lizer 05-08-2013 07:09 PM
SPI! And whatever we were spraying in paint class...but I don't remember those.
TucsonJay 05-08-2013 07:56 PM
Seems odd. In my 40+ years I've never used a 2K primer that did not require reducer... but I haven't used every brand.
Here is a discussion about guys having problems spraying the SPI 2K.
SPI Regular 2k primer problems • How to Paint Your Own Car, Auto Body Discussion Forum & Videos • AutoBody101.com
Lizer 05-08-2013 08:29 PM
Look at their tech sheet; it's not required.
http://www.southernpolyurethanes.com...ech%202006.pdf
Nor have I used reducer with it. I spray it with a 1.8 tip. I've sprayed an unreduced gallon of it through that tip. On really hot days it will come out dusty.
vespa2go 05-21-2013 08:45 PM
thks
Dear All thgks, I used an urethane 2K primer, I understood my mistake:
not enough reducer (i am living in tropical area)
pressure was 25 PSI, it should be 15 PSI.
it works very well now!
