2k urethane - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2005, 12:35 PM
New Member
2k urethane
I know this has probably been asked a million times but I did not find it scanning through. At what air pressure should I spray 2k urethane primer? Mine came out blotchy with dry and wet spots. I think my pressure was to high. It was about 40 lbs. I also am going to check my tip size.
Old 06-15-2005, 01:37 PM
302 Z28's Avatar
Need to know what gun and tip size, as usually this is the problem, not moving enough material.
Vince
Old 06-15-2005, 01:45 PM
New Member
I will check tonight. Gun is a Binks not sure what model. I will check tip size.
Vince
Old 06-15-2005, 08:41 PM
New Member
Tip Size
The gun is a Binks model 370 it is pretty old. The tip has the # 86 on it.
Old 06-16-2005, 04:50 AM
302 Z28's Avatar
I think that is the same tip my Binks model 69 has on it. I believe it codes out to be 1.7mm, which is ideal for 2K primer. Make sure the gun is clean, especially the tip assembly. Open up the material feed and shoot some test shots. Also make sure the vent hole in the pot is clear.
Vince
Bare Metal Mollard Body - Exterior 71 09-25-2008 01:48 PM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
Confused about 2k primer. firechicken383 Body - Exterior 4 05-09-2005 09:20 PM
"Basic of Basics" What are the new paints all about? Centerline Body - Exterior 0 07-26-2004 06:43 AM
Lacquer primer question badriand Body - Exterior 18 07-23-2004 03:08 PM
