Yeah, you will need to take it off and put the disc drum master cylinder back on and the proportioning valve. The proportioning valve (factory one) is for safety only.But it is a good idea to have it on. If one system ( Front or Rear )
Loses pressure ( springs a leak ) the valve inside shuttles to close off that part of the system,keeps air from purging back into the other system and keeps the system that is left functioning. Aftermarket valves for disc to disc conversion are for regulating how much pressure goes to the rear set to keep from locking the wheels. Front wheel drive cars use a similar thing for the transverse braking system that they use. Manufacturers call it a hold off valve. The aftermarket valves are nice because you can mix and match without to much regard to balancing sytem piston sizes...pad square inch etc. |
then you will be good to go. just remove the residual valve.
| Will Rear Disc's Stop Better Than Rear Drums?? | acr | Suspension - Brakes - Steering | 90 | 10-25-2012 07:01 PM |
| Builder says 1/4 more on rockers....HHHMMM? | sooper | Engine | 29 | 07-16-2010 01:17 PM |
| David Vizard's Idea of Almost Bottoming Hyd. ? | BUFFALOBILLPATRICK | Engine | 46 | 06-24-2010 02:25 PM |
| Weight of Disc Brakes vs Drum Brakes | leejoy | Suspension - Brakes - Steering | 7 | 06-29-2007 12:41 AM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
