Ok so after everybody in the world assured me my front input shaft seal was causing my problem I dropped the trans & the seal was fine.Heres whats going on.I hopd in my truck one day & drove a very short distsnce then the truck had no gears.As I poured fluid in the trans it came out of the seap hole @ the inspection cover as fast as I poured it in.While it has trans fluid in it itll shift just fine.Now Im not sure if heat is a problem but when it stops shifting if u let it sit overnite the next day it will shift just fine.
I blew the lines out but even after that the leak was still there.As I said the seal looked like new.Theres a cover / plate that sits in the bellhousing infront of the trans pan I have no idea how to or whats behind it.Does anyone have any idea what I should do next or what look for?Any help would be greatley appreciated.Thank you....95 ram 1500 5.9 360 4x4 46rh trans
