2wd 4l60e Vs 4wd - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2011, 10:08 PM
2wd 4l60e Vs 4wd
Hi... Can anyone tell me if I can use a 2WD 4L60E in a 4WD application? If so what do I have to do to get it to work. Thanks
Old 10-28-2011, 12:08 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Output shaft. 4wd is shorter and uses no extension housing since it bolts to the xfer case.
Not sure on the years they will interchange. Electronics had changes through the years.
Years/electronics aside, the trans will have to be torn halfway down to swap shafts.
4l60e 45silas Transmission - Rearend 1 09-27-2010 09:03 PM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 07:22 PM
4l60e no first 84'Monte Transmission - Rearend 5 10-10-2009 10:37 PM
LT1-350 and 4L60E Harleyvato1963 Engine 5 10-20-2008 09:19 PM
4l60e tag id # mchl_shafer Transmission - Rearend 3 05-25-2008 07:26 PM
