We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 07-15-2003, 09:44 AM
rambo_z28's Avatar
rambo_z28 rambo_z28 is offline
2WD TH350 to 4WD TH350
i have an 82 chevrolet silverado 4x4 that i need a new transmission for. the deal is i know a guy that has a 74 gmc truck that has a newer crate motor 350 and a rebuilt turbo 350 in it, but it's a 2 wheel drive. he only wants $700 for it so i'm really eager to jump on it. my question is will i have any problem switching the turbo 350 into my truck. i don't know much about transmissions, but from what i've looked at, all i have to do is pull the tailshaft off and bolt the transfer case inbetween it and the transmission. is this true? or should i just forget the whole truck and rebuild the transmission? any help would be greatly appreciated!
Old 07-15-2003, 09:59 AM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
Yes, That's all you gotta do. Replace any seals and gaskets while you are at it. Saves time then to wiat untill it goes south.
Old 07-15-2003, 05:15 PM
adtkart adtkart is offline
adtkart@aol.com
As I recall, the T350 for the 4x4 has a shorter shaft than the short shaft that is in cars and 2wd trucks. It is a matter of changing the output shaft to be able to use it for a 4wd.
Old 07-15-2003, 07:49 PM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstar
Wiki editor
Last wiki edit: How to identify a Ford V8
Wiki Edits: 709
Cool
there are two different 4x4 shafts that were used in the T-350 tranny.
The regular short shaft 4x4 unit that most folks have seen, and
For 1 or 2 years GM used a shaft that was a 6 inch tail housing 2wd shaft that was slightly shortened to fit a 208 trans-fer case with an adpater in between the tranny and transfer case.
I do not remember the years GM did this, I suspect it was the early 1980's since the 700R4 was in production too.
I would suggest a comparision some how to see if things will work
At the Bonneville Salt Flats... 130mph is known as First gear ...............
Old 07-16-2003, 06:15 PM
adtkart@aol.com
I guess they must have changed them after I quit doing trans(1984), because they used to have an output shaft that ended at about the end of the case where the tail housing attaches. There was a plate that attached in place of the tail housing, and the transfer case attached to that plate. The plate was also the mount for the transfer case. We used to always keep a couple of them on the shelf, ready to install, as 4x4's were the only thing that they would fit in.
Old 07-16-2003, 10:01 PM
Crosley's Avatar
Crosley's barnstar
Wiki editor
Wiki Edits: 709
yes GM did change them. The longer 4x4 shaft was used with the 208 transfer case. Not too many of them were used from what I have seen.
It is simply a 6 inch 2wd shaft that has been cut off slightly. It still has the hole for the speed_o gear clip!
Tony
Old 07-17-2003, 05:17 PM
adtkart@aol.com
That's one of the things that I like about this board. There is always someone that makes me feel older by pointing out the changes that I have missed over the years.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
