3.0 Tip Poly Primer Gun - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2008, 01:55 PM
Does anyone use a 3.0 or larger gun tip for poly primer; my 1.8 tip works but I was thinking of purchasing a poly primer gun with a 3.0 tip; for heavy filling. I was wondering if these tips are to large. Thanks to all; I have learned so much from all of you. Thanks again
Old 04-25-2008, 02:29 PM
Irelands child's Avatar
I use a 2.2 tip (and have even used a 1.8) which will lay it on nice and smooth. I would almost think that a 3.0 would be fine for spraying house paint
Dave W
Irelands child
Old 04-25-2008, 04:56 PM
33mopower's Avatar
33 Mopar addict
Last journal entry: 1933 Dodge commercial sedan
I use an air gunsa with a 3.0 tip for shooting polyester. It allows me to put the material on faster with no thinning. I think the polyester has made me lazy though. I used to spend more time making the mud work perfect now I just rough it in and hose on the polyester primer.
Old 04-25-2008, 06:49 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Stick with a 1.8-2.0 and let it be.
You "hose" poly on and it takes longer to cure out besides peeling it.Poly is best built in layers and one other thing.
Polymers CHIP like no tomorrow and "if" you have excessive build at edges,say doors, and you get a "hit" on it. It WILL chip off big time.
Learned this the "almost" hard way. It's fine for filling but you want a GOOD filler at an edge if you expect no problems later on or feather it out to just primer & paint.It's no real replacement for a real filler.Same goes for glazes. No where near the toughness of a true body filler.
I keep mine with a 2.0 and layer it on with 10-20% reduction with Acetone for a nice finish and quicker cure & sanding. I still give it 24 -48 hr before sanding.
polyprimer Gun tip sizes staircasesurfer Body - Exterior 16 05-20-2007 07:32 AM
reduce primer to get it thru the gun??? alteredpilot Body - Exterior 10 01-26-2006 11:20 AM
Old School - Black Primer Look - Paint Guns primerbaby Body - Exterior 11 02-06-2004 04:59 PM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 01:28 AM
Primer.....which gun 62slantsix Body - Exterior 13 06-03-2003 01:41 PM
