3.1v6 to v8 wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2007, 10:48 PM
3.1v6 to v8 wiring
hey guys
i just picked up a 90 firebird born a v6 i'm going to put in a late 70's non computer motor and th350 trans w/shift kit and 2000 stall i want to get rid of all the stuff i dont need once i have the correct wires for alt,dist thats where i need help good gosh i think the bird has more wire under the hood than my 72 truck has all together. any help would be great.
thanks don
Old 07-21-2007, 04:02 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Do you have Smog testing for your area?
Doc
Old 07-21-2007, 09:17 AM
no smog testing just safty ins. but most of the places only check your horn and lights
Old 07-21-2007, 06:08 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
To start and run the engine, the only things you need is the starter wires, (should be the same for both engines)..and the "BATT" wire for the HEI..
This will give you crank and fire..
Next you'll need to isolate the gauge group, and find the PROPER resistive senders (probably won't match your 70 engine senders) and install & Hook them up.
After that, not knowing what charging system you have / had...If it's a 12 SI GM alternator, you need one wire to the solenoid battery terminal from the alternator output lug, (fuse link it!) and the #3 red terminal jumped over to the alternator output lug, the brown wire #2 terminal goes to the charge lamp and ignition switch.
That's it..
You can strip the rest out..It's computer controlled senders..as well as the computer.
Doc
Old 07-21-2007, 09:39 PM
hey doc
thanks for the info, on the gauge cluster i was'nt planning on using any of the factory gauges am i still going to need to run power through the cluster to have head/tail lights and such? the alt, that is on the motor i'm putting in has a big wire going to the pos side of batt with a fuse and a smaller wire jumped from the lug to a side term. thats it.
thanks don
Old 07-23-2007, 02:36 PM
docvette's Avatar
Wiki Edits: 12
Originally Posted by dnk5chevy
hey doc
thanks don
Doc here,
Gauges, Nope..
But I Wouldn't run a new engine without an engine monitoring group..
I just hate it when I break in a cam at 2000 RPM for 30 minutes only to find through the smoke, it only had 2 psi of oil pressure and stuck thermostat or no water...
Doc
Old 07-23-2007, 02:51 PM
hey doc
i'm running gauges just not the stock ones.
Old 07-23-2007, 03:43 PM
docvette's Avatar
Wiki Edits: 12
hey doc
Doc here,
Then just don't hook up the senders, and pull the INST fuse.
Doc
wiring a v8 up in a s 10 blazer wolfinwv Electrical 5 01-22-2006 02:11 AM
1967 Mustang 302 V8 wiring problem bruce banther Introduce Yourself 4 11-13-2004 11:25 AM
s-10 v8 wiring tonydharley Electrical 0 03-14-2004 08:26 PM
87 s15 v8 wiring gogreen44 Electrical 2 11-13-2002 08:01 AM
87 s15 v8 wiring gogreen44 Electrical 1 11-11-2002 04:36 PM
