3/32" orbit DA with professional results Possible for Color sanding? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2011, 12:48 PM
I've been painting instruments full time for around 7 years now and I've enjoyed it.
And... I've found it's a good idea to listen to auto body guys when it comes to paint. And I figured what better place to get the opinions of AutoBody men than well... Here!
So here's my question. Around 2 years ago I finally bought a big compressor for the shop and with a big compressor comes air sanders. When I bought what I'm using now (a Dyna silver supreme 3/32" orbit) I chose it with a small orbit for final wood sanding and level sanding paint/primer. I use 220 dry for the sealer (primer) and 320 to get the final clear almost level. Then I go level using wet/dry paper. Then I buff. I usually wet sand using the DA and Klingspor brand wet/dry to 600 or 800 grit. I have some pretty aggressive wheels I use to get the swirls from the DA out but it's taking too long.
That's why I ask if it's possible to color sand with a DA? I almost wonder if my old way with a block was better and maybe faster.
Old 04-02-2011, 10:22 PM
milo's Avatar
point on positive
There are some that use a da system, I found this little Dynabrade jitterbug I'll use with water & 2000 for color/clear sanding but will stop short and finish by hand..
http://www.youtube.com/Milogarage#p/u/25/qkYTzD4gkto
and then http://www.youtube.com/watch?v=ybK9g38uW5M
minor ? - wet sanding vs color sanding cboy Body - Exterior 33 10-06-2012 06:35 AM
Color Sanding CaperII Body - Exterior 3 06-20-2008 05:28 PM
Color sanding esahlin Body - Exterior 6 11-19-2005 04:21 PM
Color Sanding jcclark Body - Exterior 9 03-15-2005 08:21 PM
what is "color sanding" ratlover Body - Exterior 3 08-05-2004 07:44 PM
