3/4 or 1/2 copper line for HVLP supply
Did some searching so sorry if I missed a thread like this.
I built a temporary paint booth in my garage and I have a 80 gallon 2 stage Sanborn compressor. Tomorrow im getting 1/2 air fittings for my Devilbiss Finishline 3 HVLP spray gun. I have not seen bigger and assuming for the best CFM/air supply at the gun ill need the biggest line I can fit. Since 1/2 fittings for the spray gun are the largest that I have seen or even make sense, Should I just plumb my garage with 1/2 copper pipe?? Will it do me any good to use 3/4 in copper piping up to my Devilbiss QC3 dryer/filter then use 1/2'' air hose?? Im doing a rear quarter panel on a 92 Miata as a practice car then if it turns out good ill most likely paint my 92 bronco. What do you think?? Thanks! |
I used approximately 50 feet of 1/2" copper line for my system. The primer gun is a FLlll and the BC/CC gun an Iwata LPH400. I have a smaller compressor and not a bit of problem with quantity or quality. Save the extra bucks 1/2" vs 3/4" for another quart (pint?) of paint, especially if this is only for a temporary system. That paint job - my AVATAR car - before final polish:
I was never a fan of yellow until now
that is some amazing looking work. I will take your advice, 1/2" it is. Thank you very much. What brand if paint did you go with?
Dave W |
I see more orange now in your avitar when comparing to the pic you posted. Very cool
The 3/4" pipe lowers your air velocity which keeps you from pushing water and debris past the traps and into the gun (which is why an air hose directly from the compressor - even with a trap/filter - blows water out the gun). |
| Recent Garage - Tools posts with photos |
| Copper Brake Line,Fuel Line | redlightning | General Rodding Tech | 6 | 08-23-2006 08:50 PM |
| rolled copper tube for compressor line? | SteveU | Garage - Tools | 1 | 08-21-2006 07:10 AM |
| HVLP Air line size? | camaro freak | Body - Exterior | 1 | 05-19-2006 12:22 PM |
| Hvlp Air Supply | Kampr | Body - Exterior | 11 | 09-16-2005 10:47 AM |
| Copper okay for trans cooler line? | cboy | Transmission - Rearend | 10 | 05-06-2005 10:16 PM |
