Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 3-4 clutch pack burn-up 4L60E
  #17 (permalink)
Old 08-23-2012, 02:18 PM
95sierra 95sierra is offline
Originally Posted by 10scnd70 View Post
Did you reinstall the 5 3-4 "load release springs"? If so, you'll have repeated 33-4 failures. What was the clearance set at? What clutches and steels did you use? Did you air check the 3-4's through the pump? Teflon input shaft rings? Worn inside pump stator/stator bushings? Did you install a new 3-4 accumulator piston in the case, or atleast check the pin wobble in the old one? Worn boost valve sleeve? Is the band burnt, too? Is the converter clutch locking up?
hey bud you seem to know what your talking about im having probs with my 95 gmc sierra shifting out of 2nd at around 25mph it will just slip didnt know if you could help me out or not
