3-4 clutch pack burn-up 4L60E - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-10-2011, 07:46 PM
Crosley's Avatar
Wiki Edits: 1659
In most situations the 5 extra spring sets in the 3-4 clutch pack are junk when removed from a 4l60e that has burned the clutch pack up.
If setup properly a new set of these springs work well in daily driver applications. If you worry about the springs being too stiff and affect clutch apply, remove one spring from each retainer. The 3-2 down shift is a bit cleaner with the springs installed
It is a good idea to reduce the height of the retainer to provide additional clearance in the clutch pack so these spring retainers do not block the pressure plates from compressing fully.
In a drag race 4l60 the 3-4 spring sets are usually left out. In most cases the builder uses a different clutch pack configuration of pressure plates and frictions, so the 5 OEM 3-4 spring setups will not function.
  #17 (permalink)
Old 08-23-2012, 02:18 PM
Originally Posted by 10scnd70 View Post
Did you reinstall the 5 3-4 "load release springs"? If so, you'll have repeated 33-4 failures. What was the clearance set at? What clutches and steels did you use? Did you air check the 3-4's through the pump? Teflon input shaft rings? Worn inside pump stator/stator bushings? Did you install a new 3-4 accumulator piston in the case, or atleast check the pin wobble in the old one? Worn boost valve sleeve? Is the band burnt, too? Is the converter clutch locking up?
Frank
hey bud you seem to know what your talking about im having probs with my 95 gmc sierra shifting out of 2nd at around 25mph it will just slip didnt know if you could help me out or not
  #18 (permalink)
Old 12-11-2012, 07:18 AM
96lt4c4's Avatar
You'll NEVER have an issue leaving the load release springs out. However, you can run into issues when reinstalling them. Hydramatics theory was that the 3=4 clutches are trying to centrifically apply at higher RPM's, which is BS. It was GM's attempt at putting a Band Aid on a bullet wound. The 5 sets of springs force the top and bottom pressure plates apart when the clutches aren't applied. The problem is, fluid pressure can't overcome these springs quick enough to put full clamping force on the clutches. I have 4L60E's running high 9's at over 140 NPH and many being shifted above 7000 RPM's. I have NEVER reinstalled load release springs since 1993 which is when I thought ALL builders learned their lesson, but apparently not. I don't have 3-4 clutch failures in my '60E's...Even after years in 12,11,10,and even 9 second cars.
Now, the reason I left this board once before was because of other "builders" arguing facts. I'm not going to subscribe to all the sensless pissing contests this time. I've SPECIALIZED in 4L60E transmissions since 1993. I know them inside out and upside down. I've done things with these transmissionsthat most only dream of. If the other "builders" here would pay more attention, instead of arguing or trying to prove me wrong, they might actually learn something. As I said, I'm not here to argue, so I'll put it simple... If you disagree with my theories or build practices, atleast be able to show me a 4L60E that you've built that runs faster than 9.7 @ 142 MPH, and has lasted for 7 years, or one being shifted at 7200 RPM's. I'm sure there are people out there who would argue with the way Rick Hendricks engine shop builds engines... Those are the guys not winning championships...LOL
Frank
I have been leaving out the load release springs on every rebuild I have done so far and have not had one come back for a burnt 3-4 clutch. My 3-4 clutch setup that I have came up with is a mixture of parts that allows 8 clutches in the 3-4 pack and gives about .040 clearance.
#7 apply ring
AC Delco stepped apply plate
friction .062 High Energy
thick steel .106 Kolene
thin steel .060 Kolene
Thin top pressure plate .157 I think
Thin snap ring .063
I have this in my personal truck and pull a 26 foot camper with it. Never a problem.
Most of the 60E's I have built have went into tow vehicles. I have never had one come back.
3-4 Clutch Pack Question ? old yukon Transmission - Rearend 2 02-09-2011 11:09 AM
700R4 Clutch Pack Air Check mican99 Transmission - Rearend 2 04-19-2008 07:53 AM
700r4 Low/Reverse Clutch Pack 123pugsy Transmission - Rearend 2 12-29-2007 08:31 AM
700R4 clutch pack air check question jws Transmission - Rearend 10 05-08-2007 08:23 PM
700r4 forward clutch pack Caesar_Mikey Transmission - Rearend 2 04-17-2005 12:51 PM
