3-4 Clutch Pack Question ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2011, 09:22 AM
old yukon's Avatar
The ASTG Update manual recommends using a high energy friction service package for the 3 4 clutch pack, GM part number : 8690923. I think it is Borg Warner ( see image).
My question is can i use it on my 4L60e 2000 model, when it recommends use in the 1987 - 1998 models? Will there be any problems with clearances and fitting?
Name:	3 4 high energy friction clutch service package.jpg
Old 02-09-2011, 10:46 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Those are the clutches and steels my supplier includes in their rebuild kits for after 2000 as well.
Old 02-09-2011, 11:09 AM
old yukon's Avatar
That sound like a thumbs up.
So no issues at all with these, do they help solve the 3 -4 clutch pack issue with regards to clutches and steels? ( not mentioning the other issues here about valves, etc, just the clutches and steels issue)
thanks for the reply 123pugsy
700R4 Clutch Pack Air Check mican99 Transmission - Rearend 2 04-19-2008 07:53 AM
700r4 Low/Reverse Clutch Pack 123pugsy Transmission - Rearend 2 12-29-2007 08:31 AM
700R4 clutch pack air check question jws Transmission - Rearend 10 05-08-2007 08:23 PM
700r4 forward clutch pack Caesar_Mikey Transmission - Rearend 2 04-17-2005 12:51 PM
Ford 8 inch Posi Clutch Pack sodas38 Transmission - Rearend 3 01-06-2005 08:51 PM
